Thread: crunch noise again
    Regular Member chris1804's Avatar
    Oct 2009
    Sandwell
    Default crunch noise again
    im getting a crunch sound again at the front of my car when i go over speed humps i dont get it all the time just now and again, i put new ARB bushes on 6 months ago it sounds like metal on metal
    Sodding Typical on Sea
    My Saab which is based very much on the Vectra has been doing my nut for the same noise. I replaced drop link's, ARB Bushes, Strut top mount, and both wishbone bushes. I firmly believe it is now the subframe bushes in the Saab (not sure if the Vectra has a similar six bush mounting system) but they are horrendous to get at and to change, and so my car is being traded tomorrow with this graunching over speed humps and lightweight clunk over potholes and will probably go to the crusher with the noise!
    I would start by going over each component and checking for play, I hope you have a better chance of curing it that I have had!!
    Regular Member simplesi's Avatar
    Aug 2009
    probably off taking photos
    Vehicle : 1.9 cdti 150
    Trim : elite
    think it an inherant problem with most vecs with standard springs i got a spring changed recently they did a health check on the car found nowt wrong only hear it on speed bumps so i juist slow down going over them
    Oct 2009
    Sandwell
    Quote Originally Posted by simplesi View Post
    well i put my hand by the springs and have got a load of **** round them because before i put grease round them and its all stuck to that so will clean it all and see if that helps, gonna lower the car soon tho so will change shocks and springs anybody suggest any good lowering springs and shocks, the cheapest ones???
  1. Horrible crunch noise when starting?!?
    By ficosaneil in forum Engine & Drivetrain
    Last Post: 28th December 2012, 22:02
  2. A little crunch
    By Imraldis in forum Engine & Drivetrain
    Last Post: 22nd October 2012, 16:10
  3. still getting a crunch
    By chris1804 in forum Suspension, Wheels & Brakes
    Last Post: 6th June 2012, 12:04
  4. Help with my vectra please crunch noise & more
    By ONEMINUTESILENCE in forum Suspension, Wheels & Brakes
    Last Post: 2nd February 2011, 23:27
  5. Crunch.....How ****ed off am I!!!!!
    By Maverick in forum Vectra C / Signum Car Chat
    Last Post: 4th March 2008, 17:12
