Thread: Changing A Thermostat
    Regular Member Kev_G's Avatar
    Jul 2009
    C:\Uk\Chester_North West
    Default Changing A Thermostat
    Looking to change the Thermostat on my 1.9 cdti Vec C as i think its goosed is this just a simple mechanical one i can do myself or is it some fandangled electric one i need to get a dealer to do?
    If mechanical any idea on how much water / coolant is required
    Kev
    Regular Member Gazza36's Avatar
    Jan 2010
    Cornwall
    It's pretty straightforward, the thermostat is Vxhall only and comes as the complete housing complete with temperature sensor. You will need some jubilee clips if you can't reuse the old clips, don't know how much coolant you will need, there are quite a few threads if you do a search.
    Jul 2009
    Thanks Gazza im assuming as its VXL only its silly money
    Administrator plasma's Avatar
    On the Forum
    369 Post(s)
    Engine : 150
    Mileage : 74000
    think i paid about Ģ30 plus vat for it
    May 2008
    St.Albans
    Where is it located ?
    May 2008
    Wiltshire
    easy job to do, i did mine took about 1 1/2 hours for the non mechanic. I had great difficulty undoing the rad drain and in the end just let the coolant come out when i removed the pipes from the housing. i am sure there would be a how 2 on here.
    the thermostat is on the right side of the block, i found it easier to remove the battery and battery box so that you can see what your doing, some one has already mention new clips, a good idea, and get enough RED anti freeze just incase you can't save it! An easy job, just take your time. Mine cost Ģ44 from the stealers.
    When you refil the coolant, just undo the bleed screw at the front of the engine until coolant comes out, start the engine and it should auto bleed the rest.
    info from tis,
    Start engine and allow to run
    Note: Operate engine with the following cycle 1 x: 30 seconds – 2000 rpm to 2500 rpm, 5 seconds idle speed, 30 seconds – 2000 rpm to 2500 rpm.
    Allow engine to warm up at idle speed until the 1st radiator fan stage is also switched on.
    Operate engine with the cycle above again 1 x
    Cooling system bleeds automatically during engine warm-up phase
    dont forget battery code, and the electric windows ( you will have to hold closed button for 5 secs on each window to get auto feature working after reconecting the bat)
  1. Replies: 0
    Last Post: 24th January 2013, 18:50
  2. New thermostat :)
    By Tigger in forum Vectra C / Signum Car Chat
    Last Post: 11th March 2010, 02:11
  3. Changing the thermostat on a cdti 120 8 v....
    By axelf in forum Vectra C / Signum Car Chat
    Last Post: 14th December 2009, 22:25
  4. Changing thermostat 3.2 V6
    By peterman63 in forum Engine & Drivetrain
    Last Post: 4th January 2009, 16:40
  5. changing thermostat on 1.8?
    By kev bux in forum Engine & Drivetrain
    Last Post: 26th January 2008, 18:19
