Thread: Obd ii - eobd or can 2003
    Aldermaston (Berks)
    Default Obd ii - eobd or can 2003
    Good morning all, could someone please tell me which of the above my car is please, its a 2003 vec 2.2 dti. I would like a code reader (hand held) not op-com just for reading troublesome codes. I have my eye on one of them u480 readers on ebay would it do the job?
    Oct 2006
    southampton
    15 Post(s)
    I have a U480 an works perfectly fine, although, now I have OP-Com it has proved that although the U480 does remove fault codes from view, the car does retain some of the stored faults which only OP-Com or Tech2 can see. HTH
    Regular Member chris_sri's Avatar
    New Mills, High Peak
    Same here.
    My U480 arrived today. Works really well. Needed to remove some codes after I fixed my MAF and replaced the thermostat and coolant temp sensor.
    And it works on lots of other cars too.
    Not a bad bit of kit for £23.
    Nov 2007
    North Wingfield, Chesterfield, Derbyshire
    Vehicle : Vectra C Hatchback Facelift
    Trim : Club
    Engine : Z18XE
    Mileage : 100085
    Bought a U480 Fault code reader last year for our 55 reg Facelift Club with the Z18XE petrol engine, but seem to remember it might not be suitable for the diesel Vectra C's registered before 2004...someone on here might confirm or deny this to be the case....
    Members experiences with this reader are posted on here.. try Search section for Fault Code Readers....
  1. For Sale: D900 Any OBD2 EOBD CAN BUS Car Engine Fault Code Reader
    By david-bell in forum General items for sale
    Last Post: 25th January 2013, 23:42
  2. For Sale: Autel Maxiscan MS509 OBDII/EOBD Code Reader
    By Mads in forum General items for sale
    Last Post: 12th December 2011, 20:19
  3. 2003 53 3.2 V6 Gsi - How Much ?
    By pjjohnst in forum How much is it worth? (THIS SECTION IS NOW CLOSED)
    Last Post: 3rd March 2009, 14:37
  4. snappon ethos obd/obd2/eobd scanner
    By dervdoc in forum Parts for sale
    Last Post: 18th June 2008, 18:13
  5. 2003 2.2 Sri Dti
    By Silver V in forum Cars for sale
    Last Post: 27th December 2007, 20:44
