Results 1 to 10 of 20
Thread: I've got a slack box.........
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Default I've got a slack box.........
    ........ Well more to the point there's loads of slack in my gear stick mechanism. Anyone out there got the same problem? If you look at THIS vid you can see there's plenty of slack on the ball and socket. Anyone know if there's an adjustment underneath the ball?
    Regular Member denzilbud's Avatar
    cambridge
    hi mate i had the same thing as that,mine was caused by a rubber o ring round the bottom of the stick snapping/working loose,take the gaitor off and have a look at the round ring/collar that the ball joint sits in
    You've got to warn me before I go and watch videos of you playing with your knob...
    And more to the point, what on earth are those trousers...?
    Regular Member Gazza36's Avatar
    Jan 2010
    Cornwall
    Quote Originally Posted by Penfold101 View Post
    LMFAO!!
    The slack doesn't look that bad mate.
    Vehicle : SRi
    Mileage : 137000
    LOL, chefs trousers
    Vehicle : SRi
    Mileage : 137000
    Quote Originally Posted by denzilbud View Post
    Top or bottom of ball mate?
    cambridge
    theres a plastic collar that goes round the top of the ball joint at the bottom of the gear stick,inside the collar a little rubber o ring sits once it snaps it works its way out of the collar i just fed mine back in snapped and its been fine since ive cant find any pics of the gear stick to show you but have a good look and you will see it
    Regular Member steve's Avatar
    Nov 2007
    Ashington, Northumberland
    yep mine is also like this! watching this thread!!!
    cambridge
    as soon as i removed the gear stick gaitor i could see the rubber ring and where it needed to go(ten min job)
    morecambe
    35 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    mine is the same
  1. slack bonnet release handle, is it adjustable?
    By taffy bhoy in forum Vectra C / Signum Car Chat
    Last Post: 5th January 2013, 11:20
  2. anyone got a wiggly/slack gearstick?
    By b1lly in forum Vectra C / Signum Troubleshooting
    Last Post: 23rd December 2011, 11:41
  3. Shunt on clutch biting and generally feeling slack
    By Damwee in forum Engine & Drivetrain
    Last Post: 28th August 2011, 11:02
  4. slack handbrake!
    By signum03 in forum Vectra C / Signum Car Chat
    Last Post: 20th August 2009, 19:21
  5. Automatic Gearbox Slack
    By Russell in forum Engine & Drivetrain
    Last Post: 4th July 2008, 13:56
