Results 1 to 10 of 17
Thread: Diesel sometimes burning too much?
    Nov 2009
    Wakefield
    Default Diesel sometimes burning too much?
    Hi all,
    I have a 56 plate 1.9 cdti 150 bhp on 66000 miles.
    I noticed sometimes the mpg on instant would be rubbish, and when this happened it would smell at the back of car near exhaust of burning too much diesel. This has started doing it more now, if i turn key off then back on its ok for a while.
    Obv im worried as this could be damaging something else?
    Hoping someone has had this prob before?
    Thanks alot in advance
    James
    Regular Member Mark0's Avatar
    Scotland
    Do you have a vectra estate? I think this may be the Diesel Particulate Filter (DPF) operating. I think there is a way to tell if the car has a DPF by checking a number in the drivers door sill (on the little vin plate thing). I think if the numbers in the box have 1.20 it means that the car has no DPF, but if it reads 0.50 then it has. I cannot be sure of the exact numbers but I know the 1.20 one means the car has no DPF. This info might narrow down your diagnosis
    Scotland
    This confirms it. Have a read at the thread linked here.
    http://www.vectra-c.com/forum/showpo...8&postcount=12
    And turning it off midway through the cycle is bad for it... When they first put it on the cars they made the glow plug light flash when it was cleaning, but people were taking the cars into the garage thinking there was a problem so they changed the software and got rid of it. It may mention it in the manual somewhere...
    Nov 2009
    Wakefield
    Default thanks
    Hi guys, thanks for replies.
    What does the DPF mean then? whats it do, and also how do i replace and cost? lol
    Ill go check the number now, thanks all!
    West Midlands/South Staffs border
    Hi,
    Not 100% sure, but someone will correct me if I'm wrong I guess
    DPF is a diesel particulate filter, basically scrubs the carbon out of the exhaust gases. Every so often it goes into a regenerate (I think its called) mode, which cleans the inside of the DPF to keep it functioning correctly. Not sure how it does it, but I remember reading about someone else mentioning their fuel economy dropped when it was going through the cleaning process.
    Dont think it needs replacing in your case, just doing its job by the sounds of it
    Might be doing it more often nowadays if you are doing smaller/shorter journeys so the engine isnt getting up to temperature, I'm pretty sure I read somewhere that diesels are not really designed for short journeys, they need to be hot to function properly and efficiently
    It cleans the soot off the filter by injecting more fuel into the engine/exhaust, raising the temeprature and literally burning it off. As above, long journeys are good for the engine, as well as the occasional thrash when fully warm. Yours sound to be working fine, but leave it to run it's full cycle if it starts. Takes about 10 minutes or so...
    Regular Member duncmill's Avatar
    Apr 2009
    manchester
    Default diesel particulate filter
    Just looked at the box on the vin i have 1.30 do i or don't i have a dpf. Any idea's please?
    Scotland
    Quote Originally Posted by duncmill View Post
    If you mean a 1.20 then no, you won't have one.
    Cars that have them are:
    Signums
    Vectra Estates
    Vectra Automatics
    Vehicle : Jaguar S-Type V6
    Trim : Sport
    Engine : Petrol
    Hi m8 just been reading ya thread and out of curiosity I looked at my door plate and mine also says 1.30 and not 1.20 or 1.50.......Confused????
    Mines a siggy 2.2 DTI Design???
    So do we have one or not? Hmmmmm interesting!
  1. Burning oil
    By GCusdin in forum Engine & Drivetrain
    Last Post: 12th May 2012, 08:52
  2. Diesel burning ! ! ! Black smoke !!! Car clonked out!!
    By Elahi_786 in forum Diesel Engine related
    Last Post: 2nd February 2012, 19:38
  3. Burning Oil
    By Paul from Derby in forum Engine & Drivetrain
    Last Post: 12th February 2011, 18:55
  4. burning smell!
    By MARK RC in forum Vectra C / Signum Car Chat
    Last Post: 1st June 2010, 19:13
  5. Help please burning oil ????????
    By matrix1979 in forum Engine & Drivetrain
    Last Post: 13th January 2010, 19:14
vectra c using too much diesel
