Thread: Coolant warning light
    Regular Member sproket's Avatar
    aberdeen
    confused Coolant warning light
    Hi guys I was on my merry way to the office this morning when the coolant warning light came on, I am wondering if when the car was serviced in Feb should his have been topped up or changed. Also what would you guys recoomend for the coolant as have not had to touch it untill now.
    Ally
    aberdeen
    Also the coolant was toped up in the service in Feb so is there any quick way of checking for a leak? because it shouldn’t have gone down that much in 3 months. i have had a quick look but can’t see anything unusual.
    Jul 2009
    The Rift, Cardiff
    Best way of finding a leak is to first check for puddles under the car where it has been parked after being used. If you dont find puddles then look for steam around the engine bay and rad that would indicate a vapour leak. Do this when the engine is hot and preferably on a cold evening with a torch.
    This was how I found out my rad was leaking, rusted along the edge.
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Get the cooling system pressure tested at your local indy garage, NOT a VX stealer. Should show up anything bad or where there's a leak.
    Regular Member Vectra_C_Chris's Avatar
    Perth Western Australia
    For me it turned out to be a rooted water pump. Started off slow but in the later weeks it literally was dumping 500ml of coolant every 2 days.
  1. coolant warning light
    By LarfinBoy in forum Engine & Drivetrain
    Last Post: 9th June 2011, 10:18
  2. V6 Coolant Warning Light
    By iani in forum Engine & Drivetrain
    Last Post: 30th May 2011, 14:12
  3. Low coolant warning light -3.2 GSI
    By RoddyKFC in forum Electrical & ICE (including SatNav)
    Last Post: 29th August 2009, 09:33
  4. Coolant Warning Light
    By parapaul in forum Engine & Drivetrain
    Last Post: 4th October 2008, 18:25
  5. low coolant warning light
    By wxmlad in forum Electrical & ICE (including SatNav)
    Last Post: 16th August 2006, 06:29
