Page 1 of 6 123 ... LastLast
Results 1 to 10 of 56
Thread: Sump Plug Stuck Fast...
    spoons
    Guest
    Default Sump Plug Stuck Fast...
    Came to change the oil on the VXR yesterday afternoon and I couldn't undo the sump plug. It was completely stuck...
    Using the 13mm spanner, it started rounding off the edges, so I stopped.
    Any ideas before I take it to the garage and pay someone with explosives to remove it?
    (I tried WD40 but still wouldnt budge)
    Worcs/Staffs/Westmids (ish)
    Box spanner?
    If it won't come undone, it must have been overtightened too..... Who did that?
    hull
    I had same prob first time i serviced it, ended up taking to my local garage to get it loosened, why do garages tighten them up so much?
    Regular Member John35's Avatar
    Jun 2007
    in a white box
    Had the same problem ended up taking it to a garage. Next time I will purchase a 6 sided socket not a 12 sided one as they slip. If its rounded then you will have to bite the bullet and take it to the garage.
    Regular Member Paddyrallyhead's Avatar
    Nov 2009
    Sligo (Ireland)
    Ya i had same problem just the last person had ruined it and then refitted it ( very nice of them i might add) got it removed and new one fitted
    Edinburgh
    Quote Originally Posted by spoons View Post
    I tried the same and then realised later that since it's a sump plug, it's sealed against oil
    Regular Member DaveW555's Avatar
    Cannock
    6 sided impact socket and a bar, where its started to round tap the edges of the head of the bolt with a hammer to push the knarled up bits back then the socket should gain better purchase on whats left of the bolt (i assume your going to fit a new bolt and washer wink wink nod nod). Hope this helps.
    spoons
    Guest
    Quote Originally Posted by DaveW555 View Post
    Yeah, just ordered a new sump plug bolt
    Full Member lizard's Avatar
    Oct 2006
    southampton
    14 Post(s)
    I have got a new magnetic one to go in when I get round to fitting it, knowing me it will 2011
    Regular Member VECTRAMAN's Avatar
    Bridgend/South Wales
    Vehicle : 1.9 CDTI Design Estate
    Trim : Half leather
    Engine : 1900
    Mileage : 116k
    Have had problems with rounding sump nut b4 so got down to Halfords bought a set of 4x4 spanners.They grip the flat of the nut or bolt u r trying to remove.Never had round nuts since, lol
  1. Spark Plug & Sump Plug Torque setting - Z18XE Engine
    By wafoo in forum Engine & Drivetrain
    Last Post: 4th June 2012, 21:15
  2. Removing stuck sump plug
    By Big Knox in forum Engine & Drivetrain
    Last Post: 29th February 2012, 18:08
  3. Tyre Dust Caps.. Stuck Fast
    By shoota70 in forum Vectra C / Signum Troubleshooting
    Last Post: 15th July 2011, 12:29
  4. Sump plug RRP?
    By mishima in forum Vectra C / Signum Car Chat
    Last Post: 25th January 2009, 21:22
  5. Stuck sump plug - oil extractor question
    By cheekylemon in forum Engine & Drivetrain
    Last Post: 2nd January 2009, 00:14
https:www.vectra-c.comforumshowthread.php110736-Sump-Plug-Stuck-Fastpage5
vectra c sump plug stuck
T47 torque sump plug
