Thread: Can't get 1st or Reverse Gears - Help !
    Rotherham
    Default Can't get 1st or Reverse Gears - Help !
    Car drove fine yesterday, go to reverse it off the drive today and crunch, pumped clutch, crunch, let car roll back a couple of feet, crunch.
    Let car roll onto road and tried to select first gear, no joy.
    Mine's a 1.8 16v on an 03
    Selected 2nd and pulled back onto drive and went out in Astra instead.
    Any ideas?
    Full Member Big Sig's Avatar
    Apart from a goosed box or worn selector?
    Regular Member DaveW555's Avatar
    Cannock
    Sounds like either worn selector rods or the selector itself to me, the cups on the ball joints are only plastic and can wear out.
    Regular Member LADmachining's Avatar
    Hampshire
    If its crunching while trying to select a gear, isn't that suggesting that the clutch is dragging / not disengaging fully?
    Aug 2009
    LEEDS
    this happend to mine in december last year, ended up getting a new box, clutch and flywheel! luckily i was covered by warranty!
    Regular Member Paddyrallyhead's Avatar
    Nov 2009
    Sligo (Ireland)
    Possibly as simple as selector aliginment needing to be done
    Rotherham
    All gears inop now with engine running, can select all gears with engine off.
    May try to set off in 2nd selected with engine off and clutch depressed then start engine and let clutch out.
    Luckily still within 3 month warranty from Perrys. Booked in for wednesday provided I can get the car to them.
    Rotherham
    Looks like clutch pedal as it's a bit sloppy and cruise control inop.
  1. No forward gears just reverse
    By ScotsDragon in forum Engine & Drivetrain
    Last Post: 20th June 2012, 23:00
  2. getting gears
    By mitch in forum Engine & Drivetrain
    Last Post: 8th December 2010, 01:43
  3. Not enough gears!
    By Flaninacupboard in forum Vectra C / Signum Car Chat
    Last Post: 17th March 2010, 08:48
  4. gears
    By howey in forum Engine & Drivetrain
    Last Post: 27th May 2008, 19:54
  5. no gears - help!
    By Digital_kid in forum Engine & Drivetrain
    Last Post: 23rd May 2007, 13:53
cannot get 1st or reverse gear vauxhall zafira
Cant get reverse vectra
