Results 1 to 10 of 13
Thread: Clutch slip
    Sep 2009
    Glasgow
    confused Clutch slip
    Hi all think my clutch is starting to slip was booting it in second gear and engine seemed to rev slightly but lost power at about 3000 rpm as my previous post my dmf is also in for repair on wed, how can i test my clutch for slipping.
    S.Shields (Newcastle)
    5th gear at 20mph and then foot to floor!! see what happens
    u can get 10,000miles on a slipping clutch if u drive nicely
    Sep 2009
    Glasgow
    what should i expect doing that
    Sep 2009
    Glasgow
    ok car should slowly speed up if clutch ok , but needle will red line and engine rev as if in neutral if its fubard.
    Leicestershire
    Trim : PreFace SRi
    Engine : 1.8 LPG
    Year : 53
    heres a good test. whack your handbrake on really hard, put the car into first gear, and lift up clutch. the car should stall. if not, then im afraid u have a fooked clutch. gona cost ya around the £350 mark. mite aswell get it fixed while repairing the dmf mate. hth.
    PaZ!
    Sep 2009
    Glasgow
    ok tested car this morning driving at 25 mph put her into 5th and accelerated, the car didn't red line or over rev and it slowly built up speed, take it my clutch is ok.
    Mileage : 000
    Try the handbrake idea. Put the handbrake in firmly. try to start off in 1st gently the rear of the car should "sink" and the car not move too much.
    Glasgow
    Think for piece of mind you should pay for the clutch kit aswell on wednesday for your own piece of mind
    How much would you want to slap yourself if the clutch started badly slipping a month or 2 after the gearbox has already been out
    Sep 2009
    Glasgow
    depends how much it will cost, are you sure at the stealers it will only cost 150-200 sterling. It's arnold shark.
  1. clutch slip?
    By Mike1.9CDTI in forum Vectra C / Signum Car Chat
    Last Post: 5th May 2012, 19:47
  2. clutch starting to slip at 44K !
    By sri matt in forum Engine & Drivetrain
    Last Post: 19th December 2011, 20:59
  3. no V5 .only green slip
    By cranny 27 in forum The 'Off Topic' room
    Last Post: 22nd March 2011, 22:00
  4. is this clutch slip?? and chucking away
    By jhalberda in forum Vectra C / Signum Car Chat
    Last Post: 18th March 2011, 13:08
  5. can clutch slip fix itself...?
    By olid2002 in forum Engine & Drivetrain
    Last Post: 19th January 2011, 20:58
vectra c clutch slipping
Slip Clutch
vectra c slipping clutch
vectra slippingclutchclutch slipping vectra c when speed up clutch starting to slip on my vectra cvectra c clutch slip when warmVectra c slipping in 5th hotvectra sri 2008 1.8 clutch slippingopel vectra c clutch slippingclutch slipping on vauxhall vetra 2009vauxhall vetra sri clutch issuesclutch failure vectra cvauxhall zafira clutch slipping
