Thread: boost sensor
    OXFORD
    Default boost sensor
    folks, cleaned out the boost sensor this weekend, thanks to the posts already entered, it was completely full of crud. sprayed it out with carb cleaner as suggested. myquestion is now what else would you suggest i do. as it was so thick should i be looking elsewhere.
    signum 1.9cdti 55 plate 110,000. im not certain what has been done to it last serviced at 95,000 any advise would be good
    thanks
    PRESTON
    as yours is a 150 maybe worth looking at this thread,
    http://www.vectra-c.com/forum/showth...=throttle+body
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    do you know if the inlet manifold has been changed ?, is the swirl bar still attatched ?, you could also remove the throttle body, clean & check its butterfly is working fully by hand, pic link included of the throttle body, and its a must to clean the EGR ''fully'', theres a 'how 2 in the how 2 section explaning this. (pic of the EGR also. the egr 'hole' in the manifold MUST be cleaned it always gets clogged up!.
    http://www.vectra-c.com/forum/showth...=107034&page=2
    OXFORD
    thanks for your help, i was amazed how much gunk was in the boost sensor
    OXFORD
    thanks for the help, link is great much appriciated
  1. boost sensor on the 120
    By SarahP in forum Engine & Drivetrain
    Last Post: 2nd April 2012, 22:25
  2. Boost Sensor & 10K Boost
    By hebdendave in forum Diesel Engine related
    Last Post: 13th February 2011, 17:43
  3. CDTI 150, 10k Boost De-Coked & New Boost Sensor
    By Vaux-Man-G in forum Vectra C / Signum Car Chat
    Last Post: 4th January 2010, 12:02
  4. cleaned boost sensor and still shows over boost
    By chowwie in forum Engine & Drivetrain
    Last Post: 14th November 2008, 09:23
