Page 1 of 4 123 ... LastLast
Results 1 to 10 of 37
Thread: cdti 150 turbo lag fixed
    Regular Member Graeme01's Avatar
    Aug 2009
    wirral
    Default cdti 150 turbo lag fixed
    alright about 3 weeks ago i decided i would chage the inlet manifold on my vectra as it had been spluttering on idle for a little while so whilst i was changing it i decided to clean out everything i could on the engine including the egr valve! Stripped the egr valve down and found the plunger to be seized so lots of wd40 later and bingo it was moving freely again and a 12v supply across the pins made sure it was popping up and down niceley!
    So after fitting the new manifold (and putting in a blanking plate made from a coke can with a 8mm hole in the middle in the egr valve aswell to try keep the soot on the other side of the gasket to the manifold) she coughed into life first time! took it for a run and had two problems one of which was a leaky fuel pump pipe which was an easy fix but the other which has been bugging me since was the complete lack of power below 2k - 2.2k revs! This wasnt present before the manifold so i has the rubber pipes chaged from the vacuum box to the actuator with no joy! After it bugging me a lot and reading some posts on here i decided to just uncluip the egr altogether and take it for a run and guess what! "PROBLEM SOLVED". Dont entireley understand why it is now boosting at 1500 revs but it is because the egr valve isnt opertaing the solenoid back and forth openeing the gap from the exhaust into the manifold, which is why it wasnt lagging before the manifold change as it was seized up ( technically blanking it off ).
    so my advice is if you are having the same problem with the lag give this ago! the car drives and picks up so much better now especially in 1st and 2nd gear! only problem i have is an engine managment light on but im sure that can be fixed by shorting the plugs wires together or something
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Or ask a dealer to Tech 2 it off.
    Gazza4
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Quote Originally Posted by Gazza4 View Post
    Gazza4
    If only they could.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    If only they could.
    They can
    Cambridgeshire
    They possibly could but I don't think they would. Some of them are a bit funny about this I think.
    Birmingham
    Right, another job for me today! If it works, im going to cut the plug odd and set fire to it!
    Thank you and pray for me!!!!!
    Bye bye Vec B
    - Hello Siggy!
    Regular Member LADmachining's Avatar
    Hampshire
    The EGR valve CANNOT be deactivated by a dealer with TECH2. Not on the 1.9 diesel anyway.
    There was a release of updated software for certain petrol engined models that disabled the EGR, but nothing of the sort for Diesels.
    Only way to disable the EGR is to map it out using the EDS ECU software from Regal or EDS themselves.
    The EGR cannot be linked out either. The ECU looks for a drop in flow through the air flow meter as the EGR valve opens. If it does not see this, code P0400 will be stored 'EGR Insufficient flow detected'. For the same reason, the EML will illuminate if a blanking plate with too small a (or no) hole is fitted.
    Birmingham
    Graeme01, dod you get an EML with the EGR disconnected? Also, does it affect performance in any way?
    Bye bye Vec B
    - Hello Siggy!
    Regular Member Telly Addict's Avatar
    Sep 2009
    Fife
    Vehicle : BMW e92 335d
    Trim : M Sport
    Engine : 3.0 TT
    Quote Originally Posted by Vaux-Man-G View Post
    You should get an eml warning light, and yes performance should be affected very positively!
    Aug 2009
    wirral
    just got the egr light on atm althought he engine managment light did come up for the first drive but hasnt anymore
    yes its definatley an improvement feels like it did before the egr was fixed still a bit of lag obv. your never going to get rid of it all but it doesnt take half an hour to spool up any more
  1. Turbo fixed but terrible service
    By the_wave_rider in forum General Motoring Chat
    Last Post: 8th June 2012, 16:50
  2. any 1 fixed a astra cdti?
    By hoochydady in forum The 'Off Topic' room
    Last Post: 12th April 2012, 13:28
  3. Misfire fixed 150 CDTI
    By pubcrawler in forum Electrical & ICE (including SatNav)
    Last Post: 13th February 2012, 22:52
  4. modified hose fixed turbo lag and no power cdti
    By winnie2457 in forum Engine & Drivetrain
    Last Post: 11th May 2010, 22:41
  5. 1.9 CDTi 120bhp hesitation FIXED :-)
    By sthomson1 in forum Engine & Drivetrain
    Last Post: 1st October 2009, 16:00
vectra cdti get rid of turbo lag
vectra c 1.9 cdti turbo lag
