Thread: Vaux-Com / Op-Com question - Screen change question
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Default Vaux-Com / Op-Com question - Screen change question
    Hi,
    Question for you Vaux-Com / Op-Com experts, users, or even just clever folk!
    Been playing with Vaux-Com to see what it can do etc..
    Is it possible to change a display screen using Vaux-Com / Op-Com?
    I have a CDC40 Opera, and I know that you need to divorce the screen from the car and then with another divorced screen, marry it to the car..
    ..but can you do this with Vaux/Op-Com?
    Cheers guys
    Anthony
    Middlesex
    Trim : SRI
    Mileage : 100k
    or thinking about it - is it just the stero itself that need divorcing and marrying?? are the screens just plug and play??
    Regular Member Niall83's Avatar
    Nov 2009
    Belfast
    what do you want to change? Not 100% but the screen and radio are married together.
    Middlesex
    Trim : SRI
    Mileage : 100k
    My GID screen has a perminant mark on it - like dead pixels, so just want to change the screen like for like.
    milton keynes
    Quote Originally Posted by AntSSSS View Post
    No need for any software to do this mate , all you need to do is swap the lcd , relatively simple , shout me if you need a hand. You can even use a screen from a half canbus to sort yours.
    Nov 2009
    Belfast
    if the sreen comes from another car i think it needs to be divorced from it first and them married to yours with tech2. I could be wrong but sure someone knows for sure
    milton keynes
    Quote Originally Posted by Niall83 View Post
    Not required if you are just doing a LCD exchange.
    Full Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    That is true,
    I did this on mine recently, when my GID started to get strange swirly marks on it, where some of the pixels were going belly up.
    I got another GID from fleabay and stripped the LCD bit out of the front and swapped them over.
    No screws within the actual display to undo, just a little white 2 pin plug for the illuniation, and two little flat ribbon cables for the pixel control.
    Took about 5 mins to do...also don't panic if the innards look different, the lcd and led assembly will simply transfer across and fit nicely.
    My duff one was an early 2005 screen, and my good one is a 2008 screen...both code DD.
    So do as kman says, just swap the LCD bit, much less hassle than all that programming guff.
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    Not quite a how 2, but this is how you strip out the LCD panel fromthe GID.
    For all you led colour changing types out there, here is a little tip.
    If you get a GID with the code DD (full can pre-facelift), then it has about 39 SMD LED's to change.
    The one in the photos is a full CAN GID - Code BK, which has only 10 LED's to change.
    If you are upgrading to GID from TID, then go for the BK if you wish to change the display colour from the standard orangey / yellow.
    Cheaper and easier.
    Back to stripping
    Pic 1 = Use a blunt instrument to unclip the back from the GID surround
    Pic 2 = Here is the insides of the GID, pre-facelift innards look different but will fit facelift shells.
    Pic 3 = Unplug the two pin connector and the two ribbon cables
    Pic 4 = Connectors unplugged
    Pic 5 = Unclip PCB and remove from shell (yellow arrows show location of SMD LED's)
    Pic 6 = remove light diffuser from shell complete with the LCD panel.
    Pic 7 = Now remove LCD panel from diffuser - just unclips.
    Now simply reverse this to rebuild...for the sake of this thread, ensure you put the working LCD panel into you existing GID assembly.
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    and
  1. another GID screen question (last one i promise lol)
    By taffy bhoy in forum Electrical & ICE (including SatNav)
    Last Post: 11th December 2011, 19:12
  2. Information screen question
    By MARKPRIOR in forum Electrical & ICE (including SatNav)
    Last Post: 26th January 2011, 09:57
  3. Nav Screen Question
    By JamieD27 in forum Electrical & ICE (including SatNav)
    Last Post: 1st October 2010, 07:23
  4. A question regarding cd30 screen
    By SRI-RICH in forum Vectra C / Signum Car Chat
    Last Post: 5th May 2010, 20:53
  5. A quick non-vaux techie question (pug 307)
    By Faz in forum Vectra C / Signum Car Chat
    Last Post: 5th July 2007, 00:05
change vectra screen in opcom to opel
