Thread: 501 Canbus SUPER BRIGHT LEDs (white)
    Regular Member m3ath3ad's Avatar
    Aug 2007
    Minehead
    Exclamation 501 Canbus SUPER BRIGHT LEDs (white)
    http://www.autobulbsdirect.co.uk/501...ght-White.html
    Has any one tried these lights out yet?? The only problem is the price 20 pounds, but then if there canbus then they got to be worth it
    Regular Member gazturbo's Avatar
    glasgow
    Ive got ones like them, from different company, there really good, used on number plate and side lights.
    Regular Member Hyperhart's Avatar
    Jan 2010
    Luton, Bedfordshire
    Vehicle : Astra GTC VXR
    Trim : VXR
    Engine : 2.0t
    Quote Originally Posted by gazturbo View Post
    Do they still strobe though.
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    So far I have not found an LED 501 replacement lamp that doesn't pulse for 10 secs or so when you switch off, and pulse with the ignition on but lights off - that includes ones claiming to be 'CanBus friendly' or'won't cause bulb failure warnings'.
    The flat 4 SMD type seem to be the best so far - rarely give a failure warning.
    The T type 8 SMD ones show a failure warning every single time.
    These ones I haven't tried yet, so if you give them a go do let us know what happens.
    Oh, and it's not an MoT test point if they pulse with the lamp check system, so no MoT failure to worry about.
    Jan 2010
    Luton, Bedfordshire
    Trim : VXR
    Engine : 2.0t
    The only other problem i have come across using LED's is that they are bringing the front indicators on permanently. LED bulbs bring the warning up as they only use 1.5 watts as standard 501's are 5 watts.
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Quote Originally Posted by Hyperhart View Post
    Front indicators ?? But they're on a totally different circuit, surely ?
    Jan 2010
    Luton, Bedfordshire
    Trim : VXR
    Engine : 2.0t
    Quote Originally Posted by Handyandy-UK View Post
    It's a weird one i know, the troublesome 2.0t i had it just brought the warning on the display but put them in my GSi turn the sidelights on and it also brings the indicators on as well.
    Jul 2009
    The Rift, Cardiff
    I've seen this on other Vectras, its the canbus system using another bulb for safety because it thinks one has blown, like with the rear's if a brake light bulb fails it will use the side light and vice-versa. Clever for safety reasons I think.
    Cambridgeshire
    i have tried these in the old vec, pulsed for ages in my car, had a warning come up about once every 3weeks but only on for a second on startup and then it went rite out, nice and bright bulbs though, and when you go to fit it is a very tight fit to squeeze them into bulb holders, but just keep pushing and they will slot in eventually!
    Aug 2007
    Minehead
    now in stock so i have bought a set now. going to see how i get on with them
  1. Best White and Bright upgrade headlight bulbs
    By Mikeymate in forum Electrical & ICE (including SatNav)
    Last Post: 13th December 2012, 16:03
  2. canbus leds
    By decks in forum Electrical & ICE (including SatNav)
    Last Post: 23rd October 2012, 22:44
  3. anyone know any super super bright t10 side lights???
    By rozzer2006 in forum Electrical & ICE (including SatNav)
    Last Post: 22nd October 2012, 22:50
  4. For Sale: x2 x24 Bright White LED Strips. Only a quid!
    By Envy in forum Parts for sale
    Last Post: 15th April 2012, 22:50
  5. For Sale: Canbus LEDs
    By lizard in forum Parts for sale
    Last Post: 21st April 2011, 20:18
