Thread: Egr removal
    salisbury
    Default Egr removal
    Been having the usual problems with very poor accelaration from stand still very evident at junctions by having to carry extra pants to change into! Once the turbo spooled up it takes off.
    looking at it, reading other threads and having done the usual mods and replacement parts as i understand the egr valve bleeds exhaust gas from the turbo which in my reckoning will reduce or slow down the time the turbo needs to spool up,and delaying full boost, so i disconnected the egr via the electrical plug to see what happens, firstly the spanner light comes on and eventually the EML light comes on but the car flies, accelatration is fantastic and no need for extra pants at junctions. On these findings i want to remove the egr completly and just make some ali blanking plates to block the holes.
    After that long winded decription what i'm asking is how does the car know that its not working is it via resitance through the valve electrical circuit in which cas can you fool it by a resitor? or is it a sensor elsewhere or can vx switch it off via tech 2?
    Thanks guys hope above reads right.
    Signum 2006 1.9cdti 150......new inlet,egr,boost vac pipe.
    Regular Member storm's Avatar
    Northumberland
    I always wondered if it was possible to fool the egr with resistor etc,also thought you could block the hole on the throttle body side and vent the egr pipe to atmosphere like a screamer pipe?
    PRESTON
    hey Doug,
    i believe there is a Fiat gasket available to semi blank the egr on the 150 engine. The egr valve bleeds air from the exhaust manifold via the egr cooler and the turbo supplies air through the intercooler up to the throttle body on the inlet manifold. As i understand it the egr and turbo are not connected in any way. There was a thread on here today that i just cant find right now, but it covered removing the throttle body and cleaning the gunk that accumalates inside the inlet manifold, where the egr attaches to the inlet manifold, which gave much improvement to the lower rev range.will continue to look for that post.
    PRESTON
    salisbury
    been ther done that.......disconnecting the dame thing is the only thing that has given me the power back. the fiat gaskets restrict but would really like to block and remove if poss.
    Another thought i had was to block the pipes but keep the egr valve connected but tucked away in the engine bay somewhere so the car thinks that it is still there?
    Aug 2009
    herts
    Quote Originally Posted by barney490 View Post
    worked for me as i have commented today already.
  1. dpf removal
    By chrislloydie in forum Vectra C / Signum Car Chat
    Last Post: 6th January 2013, 10:53
  2. Tar removal
    By Jim Bob in forum Detailing and Car Care Discussion
    Last Post: 17th April 2010, 20:18
  3. Cat removal & EGR
    By Bullylad in forum Vectra C / Signum Car Chat
    Last Post: 25th September 2009, 16:58
  4. DPF removal
    By sthomson1 in forum Engine & Drivetrain
    Last Post: 16th March 2009, 17:01
  5. Tow Bar Removal
    By korlinski in forum Bodywork & Interior
    Last Post: 30th April 2007, 21:19
