Thread: oil in coolant tank...signum 3.2 v6 manual
    plymouth
    Default oil in coolant tank...signum 3.2 v6 manual
    Hi guys
    this morning i found a thick mars like sludge in my coolant tank,does anyone have any ideas,thought the oil cooler may have given up the ghost?
    Any water in the oil? Could be a head gasket too.
    plymouth
    there is no water at all in the oil,just the exspantion tak is full of mars like sludge
    The oil coolers are right down in the middle of the vee, they were prone to failure on the older V6's, not too sure on the newer ones.
    Regular Member alanv6's Avatar
    Nov 2007
    weymouth, dorset
    Sound like the oil cooler to me, The last 3.2s in the omegas are still failing so would suspect the cooler..
    Glasgow
    Yeah this does sound just like the oil cooler, mine went i thought i had a coolant leak and it turned out the cooler was bust.
    Regular Member DaveW555's Avatar
    Cannock
    I'd go for oil cooler first if not, head gasket(s).
    Quote Originally Posted by byebyeitsagsi View Post
    Out of interest, how much was a new one?
    plymouth
    ill let you know tomorrow!
    Glasgow
    Could'nt tell you i was lucky it was covered under a warranty i got with the car, i think the labour charges are more than the cost of the part though.
    I remember at the time it happened someone mentioned on here its common on the v6's.
    EDIT: Just found my old post almost 2 years ago. The technical name the dealer gave it was the heat exchanger more commonly known as oil cooler. It would'nt have been cheap if i had to pay, the top end was stripped down to get the cooler out from the gap in the middle of the V.
  1. replace coolant tank.
    By frasedeb in forum Vectra C / Signum Car Chat
    Last Post: 2nd January 2011, 11:03
  2. coolant tank cap
    By melvin in forum Engine & Drivetrain
    Last Post: 4th December 2010, 00:05
  3. coolant tank sludge
    By vectra3.2dave in forum Vectra C / Signum Car Chat
    Last Post: 22nd May 2010, 22:39
  4. Split Coolant tank 2.8 V6
    By luke4487 in forum Engine & Drivetrain
    Last Post: 1st November 2009, 10:16
  5. Coolant tank
    By John2360 in forum Vectra C / Signum Car Chat
    Last Post: 25th January 2009, 14:09
oil in header tank not overheating vectra 3.2
vectra c 3.2 v6 water tub
