Results 1 to 10 of 13
Thread: 19CDTi Hissing Noise under acceleration???
    Jun 2009
    Doncaster
    Default 19CDTi Hissing Noise under acceleration???
    Noise started a few weeks ago and has got progressively louder, sounds worse between 2000 & 2400RPM, presumed it was a turbo pipe and have inspected the engine bay to look for perishing or splits but can't find anything obvious. Not massively competant around TDi's though so could definitely be missing something!
    Can't seem to be able to replicate the noise when the car is at a standstill though, only when it is moving and drivers window is down.......
    Please help....car is meant to be taking us on holiday next week!
    Cheers guys!
    PRESTON
    i'm sure i have seen a similar thread on here with similar issue and it turned out to be the intercooler had a split in it at the bottom. Its a bumper off job to inspect or replace it and i think they are about £180.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Or it could be the inbuilt blow off valve which therefore is a normal sound, but more likely the intercooler.
    Regular Member Dazzy2006's Avatar
    Notts
    I had exactly the same hissing noise which turned out to be the top boost hose between the turbo and intercooler had a 2" split underneath - with a bit of luck it will be that and not the intercooler
    Jun 2009
    Doncaster
    Did read the other thread and went out to check the hoses but they all seem pretty good. Wondered whether there was sufficient pressure under boost to open a hole up that would then close as boost shut down and be invisable to the eye?
    That route exhausted, think I need to consider the intercooler! Would there be anything in particular to look for? Dark areas? Fluid leaks? And would it cause the engine to run any warmer as it seems fine at present, no change in temp at all....
    Your help and suggestions are appreciated guys, useful to just bounce theories off like-minded peope, cheers!
    PRESTON
    dark areas would be what to look for as there will be some oil mist flowing through the intercooler from the turbo and engine breather, but if it's split, you should spot it easily on the ribs of the intercooler. Trouble is it will likey be bumper side of the cooler, so bumper will need to come off to check. Shouldnt have a major effect on engine temp.
    Jun 2009
    Doncaster
    Cheers Barney, massive help! Need to go and have a look at the bumper, see what kind of a job it is getting it off!
    Cheers again.
    Regular Member BigWilko's Avatar
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    Hi bud i had the same and it was the intercooler. Check the inside of the bumper and the radiator nearest the front and look for telltale oil/ residue from the intercooler just behind. £188 for the part from the stealers. I fitted it myself and it was easy. PM me if it is the intercooler and you want a hand changing it, I'm only in Barnsley.
    Sep 2009
    Glasgow
    same had my dmf changed and now this noise, how can i check the intercooler.
    Sep 2009
    Glasgow
    http://www.youtube.com/watch?v=Fu41MYrJxm0
    Cant really hear it but its when revs are at highest.
  1. 19cdti 150 odd noise ??
    By skip in forum Vectra C / Signum Car Chat
    Last Post: 20th June 2012, 21:44
  2. A/C problems. Hissing and whining noise
    By Azy in forum Vectra C / Signum Troubleshooting
    Last Post: 29th May 2012, 13:50
  3. Hissing noise 2.2DTi
    By Celes in forum Engine & Drivetrain
    Last Post: 3rd May 2009, 22:13
  4. Hissing noise when engine switched off.....
    By s0501291 in forum Engine & Drivetrain
    Last Post: 26th April 2009, 01:17
  5. hissing noise
    By johnm in forum Vectra C / Signum Car Chat
    Last Post: 29th January 2008, 22:51
insignia hissing noise
oil residue intercooler vectra
vauxhall vectra noise when accelerating www.vectra-c.com
Corsa c hissing sound when accelerating
vectra loud hissing noise
my vauxhall insignia is hissing when i turn engine off
whooshing noise when accelerating insignia
hissing noise from car engine vauxhall
3.0 cdti vauxhall . Hissing on acceleration
v auxhall. vectra hissing sound on acceleration
signum hissing noise when accelerate
vectra making a hissing sound from driver side front
vectra 19tdi turbo hiss
