Thread: Face lift fitting silver indicator bulbs - Front
    May 2006
    Kent
    Question Face lift fitting silver indicator bulbs - Front
    Does anybody know how much need to be removed to fit new indicator bulbs to a facelifted car - Thanks
    Sweden
    I would say filler neck on the left side, and airbox on the right.
    May 2006
    Kent
    I have had a quick look... but I am not sure is the light assembly has to be moved forward to gain access to be able to remove 'the plug' ? .. accume it twist ... but who knows
    May 2006
    Kent
    see how 2 thread
    Regular Member threelitresofelitesig's Avatar
    Jul 2006
    Barnsley Area
    It's fairly easy if you've got good hand eye coordination.
    I did it without taking anything major out, but you do have to remove the filler neck for the washer bottle (remembering to let it empty a bit first!)
    The lamp holder does twist and then pull out - not an easy job, and a real pig if you lose the bulb down into the engine bay (like I did) as it'll probably take ages to get it out!
    But it's a great and easy mod... makes the car look more "complete"
  1. how hard is it fitting genuine xenons onto pre face lift signum
    By deano1 in forum Vectra C / Signum Car Chat
    Last Post: 4th July 2012, 23:27
  2. Silver face lift signum a189 ashington
    By dannyjpuk in forum Spotted or put a flyer on a Vectra C/Signum or Insignia?
    Last Post: 29th April 2012, 19:16
  3. Pre face indicator bulbs
    By lee1828 in forum Electrical & ICE (including SatNav)
    Last Post: 24th February 2011, 22:52
  4. face lift xp splitter fitting
    By mrroo in forum Styling
    Last Post: 6th April 2010, 19:04
  5. Irmscher face lift signum grille fitting
    By Lump in forum Styling
    Last Post: 11th October 2008, 17:37
