Results 1 to 10 of 19
Thread: Standard SRi Brakes?
    Regular Member JDX-SRI's Avatar
    Jan 2010
    Scotland
    confused Standard SRi Brakes?
    Hi Guys,
    I've had a quick look on the forums using the search but can't seem to find the answer....
    I've got a 58 plate Vectra SRi and was wondering what the standard brake discs are on the SRi ... and are they any different to a non sport model like the Exclusiv?
    Thanks,
    Full Member Penfold101's Avatar
    Brakes are dependant on engine size mate, nothing else. Only the 2.0 Turbo, 2.8 Turbo and 3.0 diesel have larger than standard...
    Jan 2010
    Scotland
    Ok thanks for the info :-)
    What is the standard size so I know i'm buying the right one's?
    285mm vented at the front, 278mm solid at the rear...
    Brake kits i.e. disc and pad kits
    285mm fronts - 93186297
    278mm rears - 93186300
    You can buy the kits from the dealers at around 50 quid each,...
    Jan 2010
    Scotland
    Would there be any benefit of upgrading the brakes or do you think they're good enough the way they are?
    Thanks again
    Personally? I think they're shocking as they are and the 314mm V6 ones should be standard across the range. Mind you, I do now have the 345mm VXR ones...
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    you'll be fine with standard ones if you upgrade you'll need bigger wheels
    Quote Originally Posted by mattv6diesel View Post
    Nah, the 314's fit under 17's no problem mate...
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    didn't know if jdx-sri's exclusive had the 16inc wheels trims thats all cause i have the same setup as your pic
    I was going on the principle of him having an SRi, but I have a feeling you would probably fit the 16's over the 314's as my old spare wheel fitted and that was 16"...
  1. standard setup on sxi, standard or sri?
    By taffy bhoy in forum Vectra C / Signum Car Chat
    Last Post: 5th November 2012, 02:30
  2. Replies: 14
    Last Post: 3rd September 2011, 20:23
  3. looking to upgrade my standard brakes?
    By VECTRA1974* in forum Suspension, Wheels & Brakes
    Last Post: 30th July 2011, 13:13
  4. OPC/VXR brakes on standard vec
    By staverh in forum Vectra C / Signum Car Chat
    Last Post: 27th January 2011, 13:01
  5. what big brakes come standard on saabs???
    By big rich in forum Vectra C / Signum Car Chat
    Last Post: 18th December 2008, 02:17
