Thread: shed some light
    Regular Member Graeme01's Avatar
    Aug 2009
    wirral
    Default shed some light
    right i have a 1.9 cdti 150 and recentley changed the manifold as the swirls where nackered. I also blanked off the egr valve in the process using a gasket made from a can of coke with the hole in the middle!
    problem is even though the car is now faultlessley smoothe when idling theres seems to be a lot more turbo lag than before and its really starting to get frustrating! I have changed the two vacuum pipes pipes going from the vacuum box to the actuator but still no joy
    anyone else had this problem? im starting to think it could be the egr blank but not sure
    Regular Member benny's Avatar
    Feb 2006
    dudley
    is the vac box on the rear of the engine fitted the correct way up ? ...
    Regular Member winnie2457's Avatar
    kings lynn, norfolk
    If you have changed your manifold double check all the pipes you havetook off
    and also i would consider venting your oil system to atmosphere tonstopnthe oil build up from clogging your manifold up again check my diy oil catch tank thread in here you can do it for free
    Aug 2009
    wirral
    Quote Originally Posted by benny View Post
    how would i be able to tell?
  1. Anyone shed some light on this
    Last Post: 2nd June 2012, 08:31
  2. Can anyone shed any light on this?!
    By MattyStuart in forum Electrical & ICE (including SatNav)
    Last Post: 15th September 2011, 19:18
  3. Anyone shed some light please
    By paulvectrac in forum Electrical & ICE (including SatNav)
    Last Post: 1st January 2011, 15:42
  4. shed some light
    By Graeme01 in forum Electrical & ICE (including SatNav)
    Last Post: 13th December 2010, 15:04
  5. can u shed any light?
    By jun in forum Electrical & ICE (including SatNav)
    Last Post: 12th January 2009, 14:42
