Thread: Fault,PO650.showing on vectra c 1.9dti.
    stockport
    Angry Fault,PO650.showing on vectra c 1.9dti.
    Malfunction Indicator Lamp Control Circuit fault.
    The spanner sign came on briefly then went out.When diagnosed,PO650 came up.
    Can anyone tell me what this means and is it going to be EXPENSIVE.Thanks.
    Felixx.
    Wales, UK
    Do you have an indicator bulb failiure ? If so, just replace the bulb ? Unless you mean an internal sort of fault ?
    stockport
    Thumbs up felixx
    Quote Originally Posted by mark_647 View Post
    Hi Mark,There has not been a problem with the indicators or the bulbs.The spanner sign came on for about 3-4 mins then went off!!
    It hasn't happened again but when my son used his code reader it came up with PO650.
    I suppose I will just have to put it down to an OBC error and take it from there.
    Thanks anyway for your input.Felixx.
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    if the light comes on when the engine is cold for 4-5 mins its a glow plug failure i expect
    stockport
    Talking Felixx
    Hi.
    Thanks everyone for your input.I will keep my eye on things and if anything else happens "I'll be back".
    Wales, UK
    Hope its ok !
    stockport
    Problem seems to have escalated."Buzzing/crackling" noise now coming from around the multifunction screen area on the dash.
    Although spanner light doesn't always come on!!!.
    Does anyone know if there are any capacitors or relays in that area?.
  1. mil control circuit malfunction code PO650 ( no dash warning light on car)
    By richiem in forum Electrical & ICE (including SatNav)
    Last Post: 23rd January 2011, 23:08
  2. Fault code P2279 Showing.HELP!!!.Info PLEASE.
    By felixx in forum Engine & Drivetrain
    Last Post: 28th October 2010, 18:34
  3. On line manual showing parts Vectra 04?
    By hendersong in forum Vectra C / Signum Car Chat
    Last Post: 6th April 2009, 21:13
po 650 on the dashboard means what
