Thread: car pass for towbar?
    Aug 2009
    n ireland
    Default car pass for towbar?
    hello i have fitted a genuine vx towbar and proper electrics that plug in but no power so contacted vx and they told me they can,t sort without some code of my car pass ,which i don,t have is this true? i done a search but did,nt see anything about special car pass code when fitting a towbar so do you need your car pass to get power to your towbar??my car is 2002 2.o dti . any help appreciated.
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    it can be. if the power hasnt been enable before then yes.
    the dealer can supply it to you for about £30. Its to allow them to connect the tech 2 and enable it in the cars settings.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    You may not even need to get tech 2, have you looked in the how2 section?
    Regular Member steve's Avatar
    Nov 2007
    Ashington, Northumberland
    yep needed the car pass for my geniuine vx one as it has codes to get into ecu to switch on towing electrics via tech2
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Aug 2009
    n ireland
    thanks very much for the reply,s guys i will try the "hard reset" trick you never no it might just work ,i will post back with results .regards dwaine
    Forfar Scotland
    I had similar problem when fitting a 2nd hand vx towbar. Fitted fuse in 13 in fusebox in boot, no better. I then had to buy a wiring kit (witter) which includes a black box which fits into boot fusebox. Gubbed it no problem. £50 towbar, £50 wiring kit.
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Quote Originally Posted by red robbo View Post
    Just noticed your in Forfar mate, welcome to Vec-C
  1. Will my DTI pass its MOT after a De-cat?
    By Innes in forum Diesel Engine related
    Last Post: 12th April 2011, 19:44
  2. Car Pass
    By rheumatoid in forum Vectra C / Signum Car Chat
    Last Post: 28th January 2010, 16:26
  3. Car Pass
    By tammyman09 in forum Electrical & ICE (including SatNav)
    Last Post: 22nd June 2009, 14:15
  4. Car pass
    By s0501291 in forum Vectra C / Signum Car Chat
    Last Post: 2nd February 2009, 20:39
  5. PVS Car Pass available
    By cameraman in forum PVS 2007 - 3rd June
    Last Post: 28th May 2007, 16:15
