Results 1 to 10 of 14
Thread: Engine nightmare with a Vectra 1.9CDTi 150 on a 05 plate
    North East
    Default Engine nightmare with a Vectra 1.9CDTi 150 on a 05 plate
    Hi - I have a Vectra 1.9CDTi which was occasionally having problems with lack of acceleration and I would get the spanner sign.
    I was aware that this might be the swirl valve. However a month back the car would not start.
    Took it to a local garage they said probably swirl valves - need to look.
    They had a look and said they fell to pieces and need to be replaced. (£700 -ish) I said drat but if thats what it takes I'll pay it and then sell the Vectra. Thinking to save time and effort I asked if stripping down swirl valves mean we may as well do timing belt - thay said no.
    The next day they said yes we should replace it (up to £1000 now). In hind respect I think they were realising the problem was something else and the timing belt give them more time.
    They then think it might be electrical - so it gets sent to the electrical guys who say its not that.
    Then finally, they tell me that all four cyclinder are not giving the right pressure - especially two of them and my options are throw more money at it or replace with second hand engine. (They think the latter)
    How do you escape from this nightmare? Should they have tested the cyclinder pressure before anything else. Should they consider replacing a timing belt when they have not sorted out the main fault it went in for?
    The main question is what fault could it be that reduces the pressure in the cyclinder head on two or four cylinders so suddenly. Should I risk more money. Should I buy an engine. Apart from parts that have been used should I ask the garage to modify their charge or is it just one of those things.
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    What work has been done in reference to the fault...?
    Not sure whats actually been done, or just whats been said.
    Regular Member DaveW555's Avatar
    Cannock
    Sounds to me like they haven't got the faintest idea whats wrong with it. Take it to a proper mechanic next time matey not some dreamers who couldn't fix a push bike.
    North East
    The fault was the car does not start.
    Solution by them was:-
    They fitted a upgrade kit (£400) for the swirl valves etc + labour
    They then suggested changing the timing belt kit (£120) +labour.
    So that is near £1000 of work and they say its not fixed.
    They are suggesting engine replacement
    Have you had the fault codes read yet? Might help narrow it down a little.
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    did it crank over when it wouldnt start?
    Jan 2010
    Bradford
    First none starting issue i had was fuses blow.
    Second was after being used, it would either take 3-4 key turns to start or not start for a few hours, It wouldn't crank or anything it was just dead, this was diagnosed as a dodgy startermotor, which is apparently a common failure.
    However the problem returned and was now diagnosed as "intermittant ECU fault" And its currently having a replacement ECU fitted.
    Mines an 04 plate.
    Cannock
    It makes sense to change the timing belt kit when you do the swirl flaps as you have to remove the timing belt and diesel pump to remove the manifold.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    unfortunatly someone has mis-informed you!, the belt does 'not' have to be removed or replaced to change the inlet manifold!, the belt does not have to be moved, and as i did with mid mileage was far to low to even bother, and for the first post i would not be happy with work carried out as they dont seem to know what they are doing.
    Cannock
    Sorry yeah forgot you can lock the pump pulley with the bolts through the back plate, was thinking that by the sound of the garage he's using they probably wont think to do that and would have took the belt off.
  1. 1.9cdti 150bhp 55 plate vectra idle speed problem
    By Whiteknight841 in forum Engine & Drivetrain
    Last Post: 21st January 2015, 07:55
  2. 1.9cdti 150bhp 55 plate vectra power steering stopped operating
    Last Post: 13th June 2013, 14:21
  3. best vectra/signum engine to buy on a 54 plate
    By daniel1990 in forum Vectra C / Signum Car Chat
    Last Post: 15th February 2013, 15:29
  4. Vectra 1.9cdti 120 bhp 06 plate trade in
    By robintwall in forum Vectra C / Signum Car Chat
    Last Post: 19th February 2009, 16:03
