Thread: Wing mirror replacement.
    Hampshire
    Default Wing mirror replacement.
    Hey all,
    the black rim surrounding the wing mirror glass on my vectra has a large chunk missing initialy i thought it was rather simple to replace until i removed the mirror glass to find its actualy a large part of the wing mirror itself.
    i have found a replacement wing mirror to swap it with but have a few questions on how to carry this out.
    1. replacing the colour coded cover, ive seen the clips that hold this in place to the black plastic but have no idea other then brute force and breaking it to get this off as one of the clips is located about two and a half inches down a tiny passageway.
    2. the smaller colour coded section around the joint in the wing mirror can this also be replaced?
    3. lastly removing the whole unit fron the car, im assuming that the inner lining would need to be peeled back slightly to expose the fixings? is there any particular easy way of going about doing this if so?
    i have briefly searched through old threads for similar problems and didnt notice anything but apologies if this has been recently discussed.
    Many thanks for viewing
    Tim
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Quote Originally Posted by Timo View Post
    Hey all,
    Tim
    1: yes (ive used flathead screwdriver, and broke ½ of the fixing still fits okay)
    2: yes (when folded, you can see a small bit going down where to start, but take your time, and make sure the mirror is warm, as its easyer, and wont break as easy)
    3: door card off to get to the fixingpoints
    Hampshire
    thankyou for the tips Kenp, will post how i get on in due course
    Regular Member slick91's Avatar
    Jul 2009
    Newcastle
    Whats the best thing to use to stick glass back on with??? Washed mine today and noticed glass was loose and it fell off thankfully in my hand I can't seem to find the other threads on this subject ta
    Engine : 2.2 Direct
    Every thing thats sticky...
    8 Post(s)
    Quote Originally Posted by slick91 View Post
    Something waterproof and flexible. An impact adhesive for example.
    DON'T use superglue. It doesn't allow for expansion and contraction in hot/cold weather and could end up breaking the glass.
  1. Wing mirror replacement
    By SlowCoach in forum Bodywork & Interior
    Last Post: 9th January 2013, 22:50
  2. n/s wing mirror
    By andy bo in forum Vectra C / Signum Car Chat
    Last Post: 3rd June 2012, 18:55
  3. Front wing replacement
    By devore in forum Vectra C / Signum Car Chat
    Last Post: 13th December 2011, 10:05
  4. Wing Mirror
    By R-ford_Vec_C in forum Vectra C / Signum Car Chat
    Last Post: 5th March 2011, 23:24
  5. Wing mirror
    By Danwells72 in forum Vectra C / Signum Car Chat
    Last Post: 16th July 2010, 20:28
