Results 1 to 2 of 2
Thread: Charging Problems
    notts
    Default Charging Problems
    Recently had the charge light come on while travelling to work, stopped the car and checked the belts etc and found no problem. When I re-started the car the light went out OK, however by the time I got to work the battery was almost flat, tested with multimeter and showed no output from alternator. Had this tested by alternator repair shop who found a faulty regulator and worn brushes, all replaced. Refitted to car and tested still no charge. Has anybody come across this problem?
    Jim C. Vectra C 1.9CDTi 2006
    Regular Member Exclusive BV's Avatar
    West Midlands
    when you say 'tested still no charge' do you mean there was no output from the ALT
    or
    batt not charging
  1. Battery and charging etc....?
    By ronnie63 in forum Electrical & ICE (including SatNav)
    Last Post: 4th September 2012, 12:43
  2. Trickle Charging
    By AETAaAS in forum Electrical & ICE (including SatNav)
    Last Post: 22nd June 2011, 17:29
  3. phone not charging
    By davids in forum Electrical & ICE (including SatNav)
    Last Post: 5th June 2010, 07:21
  4. K & N re-charging
    By Johnytuono in forum Diesel Engine related
    Last Post: 14th February 2007, 21:49
