Results 1 to 3 of 3
Thread: rear seatbelt faulty.
    West Midlands
    Default rear seatbelt faulty.
    Hi
    I had a problem with the rear seatbelt which is built in to the larger section of the rear seat in that it wouldn't come out.
    I purchased a seat from a Vauxhall breaker which arrived today, took it out the box and the seatbelt wouldn't come out on this one either. I was told it was a working belt.
    Am I doing something wrong? I have only tried the seatbelt with the seat out of the car.
    Glasgow
    Try sitting in the seat and putting it on, if you pull it a certain way it wont budge for example if your in a crash.
    WGAF#5
    as above the belt and seat need to be at the correct position as the locking mechanisim is as simple as a ball bearing on a "float" if its in the wrong position then the lock with activate as it would if the belt is pulled hard in the event of a crash
  1. Rear centre seatbelt
    By benwalters82 in forum Bodywork & Interior
    Last Post: 21st July 2011, 17:11
  2. Rear Centre Seatbelt
    By marchmont51 in forum Bodywork & Interior
    Last Post: 26th February 2007, 13:35
  3. Rear mid seatbelt
    By Teza in forum Bodywork & Interior
    Last Post: 10th September 2006, 13:20
