Thread: Fog lights issue
    Newbury
    Default Fog lights issue
    Hi there. I've replaced a couple of bulbs as they were not working, yet for some reason the rear n/s fog light won't go on even tho the o/s is. I have tried several bulbs that do work and I have tried a different a different bulb holder assembly. Any ideas? Corroded connection, fuse? (obviously if I think it is those I should check them out before posting the question derr .
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 110000
    Its a dummy mate, even though it has a bulb, to get them to work you need to make your own loom from the working light. HOW 2 HERE
    Newbury
    you mean i'm a dummy!
    Well I didn't know that, Thanks for the pointer, things could have got messy with me sanding the connector then taking the loom apart etc. Cheers!
    Vehicle : SRi
    Mileage : 110000
    No worries mate, anytime.
    Newbury
    OK, so the warning light is still on advising I have a bulb out, yet all are working although I haven't checked reverse lights yet as it is proving to be quite tricky getting out of the car and running around the back to check if they are on only to then jump back in to stop the car, scary.
    Full Member Big Sig's Avatar
    Check the brake lights very carefully Not just that there are 2 working, but that its the same lamp on both sides.
    Newbury
    yep done, and got other people to check as well (although I should have got them to check the reversing lights as well). So may I assume that if it was a reversing light out and I get that sorted, should the warning light automatically go off or do I need to press any buttons to reset the warning lights?
    Jul 2009
    The Rift, Cardiff
    The bulb throwing up the warning may still work but it's on its way out.
    I think the system checks the bulbs are working by measuring the resistance.
    The warning will turn off automatically when the fault is fixed.
    Quote Originally Posted by danno View Post
    Don't forget if the vec knows a brake light is out it will use another bulb in its place so it will still have one each side lit up.
    Admin plasma's Avatar
    On the Forum
    185 Post(s)
    Engine : 150
    Mileage : 74000
    To test your reverse lights, ignition on (engine NOT running) put in reverse then check lol... not stick it in reverse try to outrun your car backwards and check and then get back in !
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
  1. Reverse lights issue
    By prokie in forum Electrical & ICE (including SatNav)
    Last Post: 23rd December 2011, 10:42
  2. Intermittent electric issue to do with rear lights
    By ad13 in forum Electrical & ICE (including SatNav)
    Last Post: 3rd October 2011, 12:54
  3. Replies: 2
    Last Post: 31st March 2010, 13:30
  4. Philips bluevision h7 head lights & side lights brand new
    By davidlewis24 in forum Parts for sale
    Last Post: 19th March 2009, 22:42
