Results 1 to 10 of 15
Thread: Removal of side badges&glue
    Norwich
    Trim : SXi
    Engine : 2.2
    Default Removal of side badges&glue
    I,ve got the badges off no problems and on the drivers side I was left with a sticky residue that cleaned off fine, however the other side the foam came off fine but I,m left with a very hard glue
    So far I,ve tried
    • Clay bar
    • T-cut
    • Hair dryer
    • Hot water
    • Boiling water
    • Solvent cleaner (Great for getting rid of tar spots!)
    Nothin is touching it even the boiling water does not soften it. Anyone else have this prob? If so how did you get it off because its looking like the sander is going to come out soon
    Full Member Big Sig's Avatar
    Someone hasn't super glued it back on in the past have they?
    guildford
    I softened with tar remover and then used a small amount of tcut, but it did take a while.
    Regular Member crespo's Avatar
    Bournemouth
    Sounds like it has been super glued to me mate.
    I had the same problem with mine.
    No matter what you put on it it will not come off.
    I ended up using acetone (well nail polish remover from the mrs) and used my car key to chip it off. If the panel is pretty wet with acetone the key does not scratch the panel and you can slide it along the panel and chip away at the glue.
    It worked on my car and i had a fair bit of glue on the passenger door where some burk had stuck an expression badge on.
    I only used acetone as it dissolves glue but if it is rock hard it will not touch it. I ended up using it as lubrication for the key chipping in the end.
    WGAF#5
    brake cleaner may also remove the said glue - without causing any significant further damage
    Worcs/Staffs/Westmids (ish)
    Label remover all the way, you'll be seriously shocked at how easily this stuff makes such a job.
    Used it for the same thing on my Vec!
    I also used it to remove stickers on the headlamps of my 306, once removed there was just this clean patch surrounded by scratches where the last owner tried to use wet/dry in his desperation to remove it.
    Norwich
    Trim : SXi
    Engine : 2.2
    Thanks fellas yeah it looks like super glue to be honest - right lets go chip away!
    Forum Moderator FIL 4822's Avatar
    On a French Carp lake somewhere x
    6 Post(s)
    Vehicle : Insignia VX-line RED Tourer
    Trim : No, over weight!
    Engine : Flux Core Capacitor
    Year : 1 A.D
    Mileage : Rising
    Hanging Heaton / Batley
    16 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    Rubber sanding block (no sand paper on it of course)
    It'll be off in 10 seconds!!
    Regular Member ghostrider's Avatar
    On another planet
    Vehicle : 2.0l CDTi Bi-Turbo Insginia Sports Tourer
    Trim : Vx Line Nav Sri
    Engine : 2.0
    Wd40
  1. N/side wing removal
    By stopi in forum Vectra C / Signum Car Chat
    Last Post: 1st August 2012, 17:32
  2. Side airbag removal help
    By smitd004 in forum Bodywork & Interior
    Last Post: 21st April 2011, 10:14
  3. Side light removal
    By JSYSH466Y in forum Electrical & ICE (including SatNav)
    Last Post: 16th May 2009, 20:08
  4. Side Badges
    By Paulsvectra in forum Styling
    Last Post: 1st June 2008, 01:34
  5. Side repeater removal
    By korlinski in forum Vectra C / Signum Car Chat
    Last Post: 23rd July 2007, 10:24
