Results 1 to 10 of 13
Thread: heater
    Newbury
    confused heater
    Hi All. I hoping one of you Guru's can advise on a heater issue I have. My air con needs regassing which is on the "to-do" list, but more importantly I drove a few mile home this morning when it was a bit frosty and although the fan speeds are good the air temp is pants. I moved it all the way to hot which it then blew out some warm air then went cold. I turned the dial slightly less and it went warm again and cooled, and so on. Any ideas?
    Newbury
    Plus if this helps, the temp gauge did not go up to 80 (it didnt move at all). I have researched a bit and quite a few people mention that the needle takes a long to move several miles etc. Hmmm, I'm thinking thermostat....?
    Regular Member Mark0's Avatar
    Scotland
    Sounds like the thermostat is stuck. Probably needs replaced.
    Full Member Big Sig's Avatar
    Is it a diesel? These do take longer to heat up than petrols.
    Jul 2009
    The Rift, Cardiff
    What car you got bud?
    My 1.8 is the same. Keep it on cold until the needle eventualy moves, you get heat faster.
    Like you say its most likely the thermortat or coolant temp sensor.
    The z18xe's to teand to go through thermostats.
    Regular Member Innes's Avatar
    Plymouth
    My 2.2dti temp needle used to take ages to move. I thought the thermostat was stuck open. I the thermostat and all new coolant it but it still takes a long time to get up to temperature. I think Diesel vectras just take a long time to get up to temp.
    Newbury
    it's the 1.8 petrol.
    Newbury
    Can anyone recommend a good VX supplier for a new thermo?
    Errrm main dealer? I bought one for my old astra, cost about £40 as it came complete with the housing. very easy to do though.
  1. no hot air out of heater. please help!!!
    By jonny22 in forum Vectra C / Signum Troubleshooting
    Last Post: 18th November 2012, 14:22
  2. Heater fan
    By ibbo in forum Bodywork & Interior
    Last Post: 22nd September 2011, 20:19
  3. heater
    By keith_johnson1967 in forum Electrical & ICE (including SatNav)
    Last Post: 14th February 2011, 22:30
  4. heater is on way out i think
    By dan1983 in forum Bodywork & Interior
    Last Post: 30th January 2010, 13:53
  5. pre-heater
    By andrew m in forum Electrical & ICE (including SatNav)
    Last Post: 31st October 2008, 21:51
