Results 1 to 10 of 11
Thread: dashed white lines with diagnols
    May 2006
    Nottingham
    Default dashed white lines with diagnols
    Ok...hope someone can clear something up for me...
    Double whites mean do not cross, white lines with diagnols on the approach to a right hand turn etc if theres a turn right lane also mean do not enter.
    What about dashed white lines with diagnol lines in them? I will try to find a photo to explain better.
    A
    Feb 2006
    Guttedsville
    It means whatever the copper following you thinks is right is right. Now come here, you're nicked!!!
    May 2006
    Nottingham
    MLC any comments?
    Regular Member jonno_07's Avatar
    Apr 2006
    beverley
    is this what you mean?
    May 2006
    Nottingham
    Quote Originally Posted by jonno_07
    spot on mate
    May 2006
    Nottingham
    109: Areas of white diagonal stripes or chevrons painted on the road. These are to separate traffic lanes or to protect traffic turning right.
    If the area is bordered by a broken white line, you should not enter the area unless it is necessary and you can see that it is safe to do so.
    If the area is marked with diagonal stripes and bordered by solid white lines, you should not enter it except in an emergency.
    If the area is marked with chevrons and bordered by solid white lines you MUST NOT enter it except in an emergency.
    Laws MT(E&W)R regs 5,9,10 & 16, MT(S)R regs 4,8,9 & 14, RTA sect 36 & TSRGD 10(1)
    Apr 2006
    beverley
    * If the area is bordered by a broken white line, you should not enter the area unless it is necessary and you can see that it is safe to do so.
    * If the area is marked with diagonal stripes and bordered by solid white lines, you should not enter it except in an emergency.
    * If the area is marked with chevrons and bordered by solid white lines you MUST NOT enter it except in an emergency.
    there you go then!
    Apr 2006
    beverley
    you beat me to it mate
    May 2006
    Nottingham
    lol...your car rocks, I would love to do some photos for you sometime!! I work in Witney a fair bit.
    Apr 2006
    beverley
    Quote Originally Posted by bandrew
    i'm just getting started mate!
    i'm only in oxfordshire for the next 29 days then its up to sunny hull
  1. Oil in the vac lines
    By john norris in forum Engine & Drivetrain
    Last Post: 26th November 2012, 14:06
  2. Dreams - Dashed
    By BigWilko in forum Vectra C / Signum Car Chat
    Last Post: 30th September 2012, 23:35
  3. Brake lines
    By dominic32 in forum Suspension, Wheels & Brakes
    Last Post: 16th October 2010, 23:31
  4. Signum white lines
    By roco1970 in forum Vectra C / Signum Car Chat
    Last Post: 3rd September 2010, 19:22
  5. boys and lines
    By lilangel in forum The 'Off Topic' room
    Last Post: 26th March 2008, 18:03
