Thread: 6x9's in front doors
    Full Member tubby's Avatar
    May 2007
    Norwich
    Vehicle : Vectra sri
    Engine : 2.2 z22se
    Default 6x9's in front doors
    I'm thinkin about putting some 6x9's in the front doors and was hoping that someone had some pics of the doors with the doorcards removed, I'm not to worried about drilling new holes to mount them in the door just wanted an idea of how much work will be needed plus has anyone does this before?
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    A couple of pic in THIS thread mate, and a few more in THIS one.
    May 2007
    Norwich
    Engine : 2.2 z22se
    Thanks rushy I think it might be a bigger job than I first thought,by lookin at the pics I'm probably going to have to cut the inner skin wotd ya reckon?
    Oct 2007
    Shropshire
    The face of the vauxhall speaker is about 20mm out from the door skin. I tried to fit 8" full range jbls to mine, hoping the 20mm step out from the door would bring them out enough speaker the chassis would have narrowed enough for them to go in the hole. (hope you know what i mean) No such luck.
    Alpine full range speakers often tend to have reasonably small magnets and chassis for an aftermarket speaker so maybe you could get some of those in? However I think I good set of 6.5 components would out perform them anyway!
    Vehicle : SRi
    Mileage : 137000
    I take it you've had 6x9's before? They do need a large hole. A good set of components would do the trick and also fit properly. Are you any good with fibreglass, how about custom door pods? Build up some old door cards with MDF rings/baffles, and re skin them in fabric to match the interior. If you got a set of cards cheep your not going to bin much if it all goes wrong.
    Vehicle : SRi
    Mileage : 137000
    Like THIS mate.
    May 2007
    Norwich
    Engine : 2.2 z22se
    Yeah I've got a set of pioneer 6x9's that I've have for years just wondered of I could try and fit them.I could try and get some cheap doorcards and give it a go never used fiberglass before so could be a project over the summer, if not il get 6.5 components like mucklestone suggested
    Oct 2007
    Shropshire
    I know this is an old thread but just for the record I have modified mine to fit the 8" full range JBL units in behind the factory grills. You need to sand the door card to give more clearance behind and remove and rest the grills. Then build a mount to fix them to the door. No cutting of the metal is required but I had to drill some new mounting holes. Finally the door check strap needs to be removed and filed down so it does not foul the magnets.
    It really brings the bass forward. They have been in a couple of years now with no problems....
    Vehicle : SRi
    Mileage : 137000
    You know we need pics m8
  1. clunking noise from the 2 front doors
    By peadar in forum Vectra C / Signum Car Chat
    Last Post: 26th November 2010, 23:18
  2. Signum Front doors
    By daveg360 in forum Bodywork & Interior
    Last Post: 5th May 2009, 17:29
  3. Crossovers in the front doors
    By Ian S100 in forum Electrical & ICE (including SatNav)
    Last Post: 26th June 2007, 22:04
