Thread: CCR2006 no volume
    Regular Member arnie_barney's Avatar
    Nov 2007
    Omagh, Co.Tyrone, N.Ireland
    Default CCR2006 no volume
    Can anybody shed any light on this. Going to work this morning the radio went quiet, initially I though it was the radio station or loss of reception but everything now has no volume, all radio staions, the cd changer and the mp3 player I use via the tape deck. I have power and everthing works as normal, you can hear the cd spinning, can change tracks etc but no volume.
    Any ideas or has the amplifier bit in the headunit just gave up.
    Bristol
    The volume knob on the radios are a problem does the volume controls on the s/w work ?
    Nov 2007
    steering wheel control volume doesn't do anything now either
    WGAF#5
    there is a possibility that the amp has blown - but it would be worth checking fuses - there is possibility an internal 20mm glass anti surge fuse on the printed circuit board - but the radio would require removal /stripping - you may be able to find an online service/exhange service for repairs but it could be costly
    Regular Member Exclusive BV's Avatar
    West Midlands
    I had a factory unit do this a few years ago.
    It would only cut off the volume when warm at first, then it went completely
    milton keynes
    I would try to put some pressure on the front of the HU by the volume control , it may even just be the iso block loose at the rear of the unit. Do you have an external bluetooth or handsfree kit wired in?
    Nov 2007
    I'm reasonably hands on and ok with a soldering iron so took the unit out last night, took the lid ok and looked in and everything looked ok.
    Put it back in the car and it worked, fantastic.
    Went to work this morning - 45min drive and back agin in evening and everything fine. When out to get diesel this evening and it has no volume again. Took it out again and took it apart, checked all fuses, looked for dry joints etc. Everything loks ok but still no voume.
    Going to take it to an electronics expert tomorrow.
  1. Alarm Volume
    By justin32 in forum Electrical & ICE (including SatNav)
    Last Post: 30th March 2012, 08:40
  2. no volume
    By cutchy in forum Electrical & ICE (including SatNav)
    Last Post: 28th November 2011, 17:38
  3. SatNav volume
    By Vectra49 in forum Electrical & ICE (including SatNav)
    Last Post: 7th July 2010, 21:08
  4. ICE: how to set TP volume?
    By jw128 in forum Electrical & ICE (including SatNav)
    Last Post: 27th February 2008, 22:13
  5. radio volume
    By sanny512 in forum General Chat
    Last Post: 25th February 2008, 23:25
