Thread: cd70 nav
    LINCOLNSHIRE
    Default cd70 nav
    Can anyone tell me if this system will read mp3's burnt onto a dvd! I have thousands of mp3's and before i make coasters, thought I would ask
    Phil
    Full Member Big Sig's Avatar
    No, iirc no.
    Regular Member no1golfer's Avatar
    Jul 2009
    newcastle upon tyne
    will read mp3s m8 but on cds,not dvds.
    LINCOLNSHIRE
    Thanks for the heads up
    cheers
    West
    they will deffo read mp3 but only if burnt onto cd
    Regular Member Ollie's Avatar
    Jan 2010
    Towcester
    Engine : 1.9 CDTi (150)
    Mileage : 126000
    Only on CD. There is a 'funny' with the folder naming. If you use a standard CD format then obviously you only get an album or so's worth on but the disc name, artist and title are shown on the display, each on a seperate line. If you create an MP3 CD then you can get hundreds of tracks on in as many folders as you like, but, it doesn't display the disc name and only displays the name of the lowest level folder that the tracks are in and the name of the track.
    So, if you have a folder with the artist's name, containing several albums in seperate folders underneath, then only the album name will be displayed along with the track name.
    The way round this is to create a folder containing both the artist and album name. Then the artist, album name and track name will be displayed. You also need to ensure that the properties of each track contain the track name, otherwise it defaults to the actual filename.
    e.g.
    <Lady Gaga - The Fame>
    01 Just Dance Feat. Colby O'Donis.mp3
    02 Lovegame.mp3
    03 Paparazzi.mp3
    etc.
    Then you'll get the following on the display:
    In the audio menu you can then use 'album' to select the album and then 'track' to select the track within that album.
    Hope that helps!
    LINCOLNSHIRE
    Thanks Ollie will give it a try tomorrow, is there any other way then of adding a usb device to this system, so I could just have a memory stick to plug in!
    Full Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    This is only possible by buying one of those expensive interfaces, such as a Denison ICE link, or a Parrott 9100 etc from an Audio / I.C.E. fitting agency / supplier / shop.
    CD70's manufactured by Siemens VDO before late 2007, do not even have a facility for a basic Aux-In plug.
    CD70's after this date (I think made by a different company), only come with the option to fit an Aux-In lead...very few actually come with Aux-In connection fitted in the cubby hole under the heater / air con control panel.
  1. CD70 and Aux in
    Last Post: 8th January 2013, 13:59
  2. Cd70 please help!!! :)
    By jones5n in forum Electrical & ICE (including SatNav)
    Last Post: 22nd June 2011, 10:34
  3. Cd70
    By gregc in forum Electrical & ICE (including SatNav)
    Last Post: 11th November 2010, 02:32
  4. cd70
    By wstwatson in forum Vectra C / Signum Car Chat
    Last Post: 22nd June 2009, 20:51
