Results 1 to 3 of 3
Thread: knock from engine as pulling off 2.2 DTI
    Default knock from engine as pulling off 2.2 DTI
    Hi,
    I have noticed on my 2.2 DTI that as I am pulling off, there seems to be what sounds like a knock coming from the engine, but as soon as I've pulled off it's then gone, Now I have a sticking calliper on the drivers side rear wheel so I don't know if it's just that putting the engine under more strain at very low revs, or there's a problem somewhere. I only notice it when the windows are up, if the windows are down then the engine seems too sound fine.
    Also when changing gear, I can hear the turbo "dump" and also hear the turbo through acceleration (when window is open), I wouldn't have thought you would hear this on a diesel really, is this ok or maybe a small problem e.g boost leak or something?
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Quote Originally Posted by Rennie View Post
    Hi,
    Check the radiator mounts matey, they are a common problem,
    And as for the turbo noise....welcome to the world of the DTi
    It's totally normal
    It's totally normal
    I noticed earlier on while cleaning the car that the engine cover isnt bolted in at all, just loose, but will check the radiator also when I go back out in a minute,
    Cool, glad its normal, as can't beat a little bit of dump noise when changing gear haha.
    Thanks for the reply pal.
    Adam
  1. Help Needed Please...Knock knock...
    By wishy1976 in forum Suspension, Wheels & Brakes
    Last Post: 23rd March 2012, 00:34
  2. Knock, Knock, Knocking...
    By Carmaduk in forum Suspension, Wheels & Brakes
    Last Post: 25th May 2011, 22:20
  3. Knock Knock whos' there
    By lizard in forum Suspension, Wheels & Brakes
    Last Post: 8th November 2009, 21:18
  4. Knock Knock Knockin on heavens door
    By lizard in forum Engine & Drivetrain
    Last Post: 17th January 2009, 00:10
  5. Don,t knock the NHS
    By ed taylor in forum The 'Off Topic' room
    Last Post: 3rd March 2008, 19:49
dti engine knock
