Results 1 to 10 of 18
Thread: just had car at garage....
    Regular Member chrissri82's Avatar
    Apr 2009
    airdrie
    Default just had car at garage....
    because of a slight hesitation when trying to drive 'economically' through the early gears. the car seems to very slightly kangaroo.
    also when changing gears the revs dont drop for a second or so and changing gear and means you have to catch it perfect every time.
    anybody else have this on there 1.8 vvt?
    garage tech2'd it and updated software apparantly.
    Milton Keynes
    I found this in 1st to 2nd and 2nd to 3rd when trying to drive eco in my 1.8..... is it a problem that need's tech2ing?
    Apr 2009
    airdrie
    meant to add, the mechanic advised that the revs staying up is the way the car is designed to run to aid gear change.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    TBH the 1.8VVTi needs revs. It's just the way that a variably timed engine works. You may find that you actually get better economy just driving the car normally
    Blantyre
    Quote Originally Posted by chrissri82 View Post
    Is the 2.2 Direct also designed this way, ??
    Regular Member Exclusive BV's Avatar
    West Midlands
    I find the same with mine you have to time the gear change/revs perfect every time.
    Did the garage actually change anything then?
    What are the results?
    Apr 2009
    airdrie
    the garage said they updated the software.
    i also done the air box mod yesterday while changing headlights and sidelights and the hesitation doesnt seem to be there at the moment but revs staying up is still the same.
    West Midlands
    My revs dont stay up like yours though.
    They just drop back like any normal car between the gear changes.
    When I first got the car, i noticed that the 'Fly by Wire' throttle was very laggy and i coud'nt blip the trottle because of the delay.
    It seems to have speeded up a lot now i've had a chance to blow out the cobwebs
    Regular Member crespo's Avatar
    Bournemouth
    I had this exact same problem on a Focus i had. Took it to many mechanics who either said it is designed for the revs to raise slightly when changing gear to aid gear change or to burn excess fuel because of emissions regulations.
    Both scenarios turned out to be mechanic talk for we dont know why it is doing it.
    So i took the situation in to my own hands and made an educated guess and changed the throttle position sensor (pretty cheap and easy to fit) and guess what problem solved.
    My symptoms were the revs would raise by 1 or 200 rpm when changing gear and would be worse when changing gear when driving enthusiastically.
    Which resulted in having to delay the gear change for the revs to drop so i didnt look like a learner driver.
    Oh and any hesitation is likely to be the MAF sensor. Unfortunately these dont throw error codes when they are faulty so are hard to diagnose.
    Regular Member Rebellion8878's Avatar
    Jul 2009
    Bucks
    Two astra's and my vectra slighty rev when changing gear so I presume it was normal and I also found my 1.8VVT is more eco driving it between 2k-3k rpm than 1.5 and used more fuel cruising at 30 in 4th than 3rd doing more revs.
  1. garage!!!!!!
    By mr f in forum Vectra C / Signum Car Chat
    Last Post: 25th April 2010, 09:13
  2. car in garage
    By luke.oldham in forum Petrol Engine related
    Last Post: 12th April 2010, 12:12
  3. Mod your garage!
    By fikse in forum Vectra C / Signum Car Chat
    Last Post: 16th June 2009, 18:21
