Thread: Brake pad sensor
    Oct 2009
    sleaford
    Default Brake pad sensor
    Hi just about to change the front discs and pads, if I cut the pad sensor wire will the warning light stay on?, didnt bother buying the sensor as I probably wont have the car when the discs need replacing again.
    Ely, Cambridgeshire
    60 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    If you can't be bothered to replace the sensor, just join the two wires together and the light will go off.
    Quote Originally Posted by philjensam View Post
    It's less than a tenner for the sensor. If you can live with the guilt of the next owner not being aware the low brake pad warning isn't working and has an accident as a result of worn brakes........
    That's looking at the worse case senario obviously.
    N.Ireland
    The car is up for MOT tomorrow night,was just wondering would they fail it if the brake warning light is on,I tried joining and unjoining the wiring but the warning light wont go out.I'll be keeping the car for a long time yet,wont be giving someone else the problem,the brake pads were replaced a few weeks ago.
    coatbridge
    no it wont fail for the warning light being on
  1. Fitting & Installation of ABS Harness & brake Help sensor sensor
    By Elahi_786 in forum Suspension, Wheels & Brakes
    Last Post: 17th April 2012, 20:46
  2. Brake pad sensor
    By tubby in forum Suspension, Wheels & Brakes
    Last Post: 26th July 2010, 21:21
  3. Brake pad sensor
    By benwalters82 in forum Suspension, Wheels & Brakes
    Last Post: 22nd July 2010, 18:43
  4. Brake Pad Sensor.. How far can I go?
    By aaruck in forum Suspension, Wheels & Brakes
    Last Post: 19th August 2008, 19:18
