Results 1 to 10 of 11
Thread: brake warning light on
    Jan 2010
    Windsor, Berkshire
    Default brake warning light on
    Hey there,
    Got an 04 vectra C 2.2 Direct and as i started the car this evening to leave work i noticed my brake warning symbol appeared which the manual states is informing me low pads on the front. (it's the symbol with a circle and some blocks going round it)
    Well, i quickly checked erm and there is loads of pad left on both, in fact i would say they were only put on recently (i only got the car in jan of this year)
    So driving home i tested the braking and there is no difference, i mean, it brakes fine, no noises, no funny feelings from the pedal and the car stopped perfectly when i wanted it too.
    so would i be right thats its a senser issue of some kind? and more importantly, is it going to be expensive
    scotland
    I just got one from the bay for about 6 quid . 5 min job to replace it , remove left wheel and just replace it as the old one comes off .
    schimples
    Jan 2010
    Windsor, Berkshire
    ahh nice one, is there only one then for one side?
    just checked Mr. Bay myself and there loads on there so ill grab one of those i suppose i see what i can do, cheers mate
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    just the one on the left side G
    Jan 2010
    Windsor, Berkshire
    okay cheers buddy, no worries,
    it kinda weird you know, it doesnt come on all the time, i drove to work and it didnt come on, then on the way home again it comes on, i drive a bit, turn engine on and off, then doesnt come on till i get home. Its if it just loose or something, still for a tenner might as well replace it anyways
    cheers guys
    Regular Member BIG-G's Avatar
    Oct 2009
    thurso
    you will need to check the sensor as there is two kinds a long one and a short one.just done mine
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    You can even cut and twist the wires together if you want.
    Jan 2010
    Windsor, Berkshire
    err rushy, isnt that being a bit naughty
    ... though, hmmmmm
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    No not at all, no laws or MOT regs being broke. The sensors only a indication. It only checks the front left inner pad. The rear inner pads wear faster so its really quite useless TBH. Mine had never been changed and over time the insulation broke down and it went off on new pads, really there needs to be 4 sensors.
    Jan 2010
    Windsor, Berkshire
    ahh, okay rushy, no worries, wasn't too sure
    well, i changed the sensor today, took be about 20 mins in total and now the worn pad indicator is off.
    The one i took off looked like it had been on there quite a while, i thought they were suppose to be changed with each pad change
    anyways, cheers guys,
  1. Brake Warning light and display error message , BUT BRAKE LIGHTS ARE WORKING FINE
    By JACKALG1 in forum Electrical & ICE (including SatNav)
    Last Post: 24th May 2013, 18:56
  2. 3rd brake light warning
    By madvenny83 in forum Vectra C / Signum Car Chat
    Last Post: 22nd November 2010, 07:26
  3. Brake warning light
    By dandsi in forum Suspension, Wheels & Brakes
    Last Post: 9th January 2010, 16:32
  4. Spanner light & 3rd brake light warning?
    By simp_2.2sri in forum Electrical & ICE (including SatNav)
    Last Post: 5th December 2008, 17:32
  5. Brake warning light
    By scar_vectra in forum Suspension, Wheels & Brakes
    Last Post: 23rd June 2007, 12:48
