Thread: Diesel Leak 2.2dti
    Regular Member Suffolk Boy's Avatar
    Apr 2008
    NEWMARKET
    Default Diesel Leak 2.2dti
    Hi, today carried out oil filter and oil change plus fuel filter on my 2002 Sri
    2.2DTI. While laying under car noticed wet area around fuel pipes under
    near side of car . The drip comes from a box which looks like a small rad,
    its ali with two pipes coming out back heading to fuel tank , this is first
    derv car I have had and dont know what box is While engine is running
    there is slight drip .
    Does anyone know if this is a common problem and if the ali box is
    prone to crack and leak or is this likely to be just a pipe leaking.
    Car runs fine and starts fine and due to working away from home have left
    it till next Monday when I can have a proper look.
    Any advice would be much appreciated .
    Reading
    Default \fuel Leak
    Hi, have the same problem, can anyone tell me what the part is, and what it does, and how much of a pain is it to change?
    Many thanks in advance
    Mark
    Nottinghamshire
    The small radiator under the floor under the passenger seat cools surplus diesel from the pump before it goes back into the tank. If you follow the pipes you'll find the temperature sensor that diverts the returning diesel through this radiator if it's too hot to go straight back into the tank.
    You need to check with your dealer but it looks like the radiator part number is 13126698 and comes with the pipes attached. Vauxhall refer to it as 'Radiator, fuel cooling, return flow, with pipes'. There are a few fittings shown with it which you may also need if yours have corroded. There's a special tool for the QR fuel pipe fittings or you can use a screwdriver or similar to press in the 2 tabs to release.
    Apr 2008
    NEWMARKET
    Quote Originally Posted by James24 View Post
    All the new part is , is a pipe they have done away with the rad and just linked the pipes , I brought the proper Vauxhall part and it was about thirty odd quid, I had hte dealers fit it which was a hour labour, I would now do it myself and just buy some fuel line, remove the rad and join the two ends together and save a hundred quid.
  1. Slight diesel leak from Diesel filter housing :-(
    By rollercoaster63 in forum Engine & Drivetrain
    Last Post: 22nd July 2015, 21:18
  2. 2.2dti vacuum pump leak
    By Al 22 dti in forum Engine & Drivetrain
    Last Post: 3rd April 2011, 15:07
  3. 2.2DTI Coolant leak
    By Innes in forum Engine & Drivetrain
    Last Post: 14th March 2011, 21:17
  4. Oil Leak 2.2DTI Help Please...?
    By congaman in forum Vectra C / Signum Car Chat
    Last Post: 11th October 2010, 17:56
  5. oil leak from injector tube 2.2dti
    By Beavis in forum Engine & Drivetrain
    Last Post: 11th April 2007, 08:00
