Thread: Removing rear brake pads
    Regular Member strothrc's Avatar
    West Mids
    Angry Removing rear brake pads
    Have managed to remove the calipers, and replaced one side, but the drivers side piston will NOT go back in, seems to just be spinning round...
    Any ideas please?
    Regular Member signumturbo04's Avatar
    SCOTLAND
    clamp off flexi-pipe, release the bleed nipple andf will go back in easily.
    Regular Member John35's Avatar
    Jun 2007
    in a white box
    Use firm pressure on the piston whilst turning. Once it goes, it fairly easy. What are you using to wind the piston back in??
    West Mids
    No other possible way, apart from that?
    West Mids
    Quote Originally Posted by John35 View Post
    Have used very firm pressure! Two bolts attached to a plate, they fit, and turn it with a socket attached to the top...
    Regular Member DaveW555's Avatar
    Cannock
    crack the bleed nipple with the flexi pipe clamped up, if it doesn't go back then its a new caliper, common problem, where in the midlands are you coz ive got the proper air powered winder for them
    West Mids
    Thanks for the offer dave, didn't have time to finish last night, so got the dealer to do it along side service/MOT...
    Thanks for the help!
  1. Fit brake pad wear sensor without removing pads?
    By James24 in forum Suspension, Wheels & Brakes
    Last Post: 23rd December 2009, 21:41
  2. Rear Brake Pads
    By steve-wolves in forum Suspension, Wheels & Brakes
    Last Post: 17th August 2009, 14:18
  3. Rear Brake Pads
    By cp123 in forum Suspension, Wheels & Brakes
    Last Post: 24th May 2009, 13:15
  4. rear brake pads
    By swainey in forum Vectra C / Signum Car Chat
    Last Post: 16th February 2009, 21:23
  5. Rear brake pads
    By T4M in forum Vectra C / Signum Car Chat
    Last Post: 17th August 2007, 22:17
