Results 1 to 3 of 3
Thread: Yet another thread about a 'knocking noise'
    Regular Member beethamwest's Avatar
    Jul 2009
    Liverpool
    Default Yet another thread about a 'knocking noise'
    I have obviously done a seach on here, 99% suggest the ARB's, some say dop links and so on.
    I would compare my noise to that of something loose in the boot, however sometimes with continuously crap roads with multiple holes, it can sometimes sound like a squeak/knock/undewate noise
    I know this is so random, but i can't describe it.
    Yes i have ecently had 30mm lowering by PI. And my front was fist to make the noise (needed to tighten the top bolt which connects the Anti roll)
    But now the rear. I bounce the car and it doesnt do the noise, thee seems a tight fit aound the antiroll were the bush is.
    CARSSSSS!!!
    LEAMINGTON SPA
    Believe it or not there are two known faults, I is the radiator mounting which are normally done, if you complain as it is a recall, the second is the Gasprings on the boot, if they have leaked, they make a terrible racket, don't be coned they are very easy to change so DIY, The final this to check is gravel in the front spring seatings, All small things, but can make a big difference for little cost.
    Regular Member Exclusive BV's Avatar
    West Midlands
    I thought I had a suspension knock the other day.
    Turns out it's my back shelf jumping up and down
  1. Knocking noise
    By The boy in forum Suspension, Wheels & Brakes
    Last Post: 3rd July 2012, 13:02
  2. knocking noise
    By VECTRAMAN in forum Vectra C / Signum Car Chat
    Last Post: 28th July 2011, 17:23
  3. knocking noise
    By chrissri82 in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2010, 17:17
  4. Not another knocking thread....
    By parsco in forum Vectra C / Signum Car Chat
    Last Post: 26th November 2009, 11:34
  5. 1.8ls knocking noise-help!
    By bri.gsi in forum Engine & Drivetrain
    Last Post: 17th January 2008, 18:25
