Thread: inner track rod removal
    Regular Member eaglepva's Avatar
    Up North
    Default inner track rod removal
    I changed the outer track rod ends today on my signum took about half hour each side to do. unforunatly it has not solved my wheel vibration issue that im having. So i am going to have to do the inner track rod and see if that solves the problem.
    Do i need a special tool to remove the inner track rod end any help/tips much appreciated
    Regular Member hagga's Avatar
    kingswinford
    nope..just spanner .. though a foot helps too(quite tight).. oh and about 30 squid from vx (bought one today) (full opposite lock makes it accessable too)
    kingswinford
    pretty sure you may have asked...but you sure its not something else?
    Tyneside
    You'll need a 36 and 22mm spanner IIRC as i changed the near side last week, but we got a tool from a local garage that's designed for the job so it was piece of ****. Tried to get hold of a 36mm spanner from a shop before we went to the garage and nobody that I tried stocked them.
    Up North
    Quote Originally Posted by hagga View Post
    The guy that does the work on my car, fitted new disk and pads couple of months back and when he brought the car back he said that the track rod bar or summit like that cant remember what it was was showing signs of wear and would be causing my wheel vibration.
    Thought i would try and fit it myself as i need a new set of tyres on the sigbum so trying to keep costs down lol.
    kingswinford
    Quote Originally Posted by mark1319 View Post
    I just used large adjustable on inner rod ball housing..there weren't any flats on rack end.
    Quote Originally Posted by eaglepva View Post
    it's an easy job.. make sure you measure where rod end is so you wont need it retracking
    Tyneside
    There is a small flat that's sits behind the thread on the rack.
    kingswinford
    not on mine..rack may differ slightly on others though.
  1. track rod ?
    By peadar in forum Suspension, Wheels & Brakes
    Last Post: 13th March 2012, 22:44
  2. track rod removal
    By neill in forum Engine & Drivetrain
    Last Post: 3rd November 2011, 23:49
  3. Been to a track day
    By bandrew in forum General Chat
    Last Post: 27th May 2010, 15:32
  4. Track Day.
    By mally in forum Vectra C / Signum Car Chat
    Last Post: 25th May 2010, 18:20
  5. Track Rod Ends or Inner Track Rods
    By Padster72 in forum Suspension, Wheels & Brakes
    Last Post: 28th April 2010, 11:41
