Thread: Display & cd player problem - help please
    Regular Member alexander08's Avatar
    derry
    Default Display & cd player problem - help please
    hey.. got a problem that i hope someone can help with.. the display above my radio stopped working around 2/3 months ago but it wasn't top of my list with the mot/tax coming up at the time so i left it but now the battery bit the dust (had to get a new one) and the radio won't come back on (guessing it just needs the code?) but with no display what can i do? it's really starting to get to me now.. its shocking driving without the radio/cd player lol.. i've almost resorted to taking out a portable cd player lol.. please can someone help me sort the dash + cd player.. i'm begging at this point lol..
    btw its an 03 pre-facelift vectra-c 2.0dti (if that helps at all lol)
    THANKS IN ADVANCE FOR ANY HELP
    derry
    Bump! Help..!! Please..!!
    Full Member Big Sig's Avatar
    Have you tried a new screen?
    Regular Member Exclusive BV's Avatar
    West Midlands
    Do these things not come as a pair? I thought they were coded to each other
    WGAF#5
    your problem without a screen is even if you do manage to get into a postion of attempting to enter a radio code you have no way of confirming what the radio says before you confirm it ...so you could end up locking the radio ..... you need to establish the reason your screen failed - tehn you can enter the code
    Full Member Robsey's Avatar
    North East Cheshire
    14 Post(s)
    Trim : Energy
    Mileage : 131,000
    you need to establish the reason your screen failed - then you can enter the code
    Don't suppose you checked the obvious free stuff like the fuses...all 4000 of them...well not quite that many but if it helps, just check these in the end of the dash panel.
    Fuse 1 = Entertainment Head-Unit
    Fuse 4 = Accessory (where fitted)
    Fuse 7 = Display and Instruments - Via BCM
    Fuse 9 = Display and Instruments - Via BCM
    Fuse 10 = CIM module
    Fuse 12 = Overload protection fuse...very common failure. (BCM)
    Fuse 17 = Instruments and Display - Via BCM
    Fuse 26 = Instruments and display
    derry
    lol.. i might have to give it to someone else to have a look at then because i'm out of my depth with any of this electrical stuff just wondering though.. if i get a new cd player/radio will it work ok? thanks for any advice..
    edit: @ robsey.. i checked all the fuses under the bonnet beside the battery and they all seemed ok.. (not sure of what numbers they are though) and i've no notion where the ones inside are because where i thought they would be i couldn't see how get to them lol..
    North East Cheshire
    14 Post(s)
    Trim : Energy
    Mileage : 131,000
    Quote Originally Posted by alexander08 View Post
    Wrong fuse box...
    Look at the one at the passenger end of the dash panel...
    You will need to open the passenger door to see the plastic cover panel.
    It will have a sticker on regarding the airbag, but the airbag is in the dash not behind the panel.
    Just pull out the plastic panel (firm tug with your finger) and your fuses are in there.
    look here
    http://www.vectra-c.com/forum/showthread.php?t=104416
    derry
    thanks robsey.. i was looking at that today when i was looking inside for this supposed fuse box but i seen that sticker and stayed well clear then lol.. i'll give it a look in the morning.. i'll film it anyway incase the bag does go off in my face.. it'll be something for youtube lol..
    North East Cheshire
    14 Post(s)
    Trim : Energy
    Mileage : 131,000
    No problem...the bag is above the centre of the glovebox...in the upper section of the dash panel...absolutely no chance of setting it off accidentally.
    Did you do anything at all three months ago to the car...it may have some relevance to your display problem!! such as -
    Screen plug left undone / loose....
    very common one is changing the glove box bulb...loads of people have blown fuse 12 doing this!!
  1. t8919g dvd player problem.
    By peitsamo85 in forum Electrical & ICE (including SatNav)
    Last Post: 11th July 2010, 18:48
  2. Pls recommend me new player/display?
    By Wesu in forum Electrical & ICE (including SatNav)
    Last Post: 28th June 2008, 15:56
Vauxhall vectra c fuse for CD player
wheres the cd player in vectra c
