Results 1 to 5 of 5
Thread: What would cause uneven brake pad wear?
Hybrid View
    Regular Member Nato's Avatar
    Mar 2010
    Risca, South Wales
    Default What would cause uneven brake pad wear?
    I've just gone out to the car to check what type of pad is on the rear, and I've noticed that the pads have worn unevenly. The n/s pad has a few mm left on it, but the o/s pad is down to the metal, which has been causing the grinding noise which made me think I needed to do brakes all around. The front pads look nearly new. What would cause the uneven wear on the rear pads?
    Also, when I went to buy pads from my local factors, they told me there are two different types of pad for the rear - one with a pin that loops through the top, and then another that looked totally different. Can anyone shed any light on this?
    Regular Member hoochydady's Avatar
    Jan 2010
    glasgow
    yip u ethere have a cheap set of pads on it or not the rite 1s or u need to do ur discs to they may have been to worn and this has shortend the life of the pads
    Cumbernauld, Scotland
    Uneven pad wear is very common, especially towards the end of their life
    A few mm is nothing
    I would be more concerned if one surface had at least 25% of the material remaining and three were worn to the last 2mm
    Aug 2009
    LEEDS
    they all wear un evenly i think, all my cars iv had have done
    Regular Member carpet's Avatar
    Jul 2006
    TENTERDEN KENT
    If the pads are worn uneven to any great extent the problem could be the caliper sticking on the guide pins. These are the pins that the caliper mounts/runs on that you undo and remove to replace the pads. Apply some grease and ensure that the calipers move freely when you replace them.
  1. uneven wear
    By neill in forum Suspension, Wheels & Brakes
    Last Post: 17th October 2010, 14:42
  2. Uneven tyre wear
    By m8internet in forum Vectra C / Signum Car Chat
    Last Post: 15th February 2010, 15:16
  3. uneven brake wear ?
    By Lump in forum Suspension, Wheels & Brakes
    Last Post: 21st May 2009, 20:24
  4. Uneven rear brake wear
    By Wingnut in forum Suspension, Wheels & Brakes
    Last Post: 1st February 2009, 20:51
  5. Uneven Tyre wear
    By Manni2375 in forum Suspension, Wheels & Brakes
    Last Post: 23rd July 2007, 15:19
vectra uneven brake pads wear
vectra c rear brake pad uneven wear
vectra pad wear uneven
https:www.vectra-c.comforumshowthread.php110274-What-would-cause-uneven-brake-pad-wear
