Results 1 to 10 of 13
Thread: Air Con Query
    Brighouse
    Default Air Con Query
    Anyone recommend an aircon engineer (mobile or garage based) in Brighouse/Bradford/Leeds/Halifax area?
    Local garage identified that the system on my Vectra C 1.9 CDTi won't repressurise but can't identify fault - so needs further investigation.
    Martin
    Regular Member Super T's Avatar
    May 2007
    On the Levels
    Purge with nitrogen 10psig and spray components with leak spay(soapy water).
    Regular Member yessof's Avatar
    Jan 2008
    west yorkshire
    HI mate got mine checked and regassed last week by AB Aircon servicing between Queensbury and Halifax. Andy Bateman 01274 814237 or 07740257284. Give him a call.
    Brighouse
    Thanks SuperT and yessof. Will try AB Aircon (don't know my way around an engine bay).
    Martin
    Jan 2008
    west yorkshire
    When I took mine the first thing was to test for leaks using nitrogen and dye which will show any leak. No point in filling system with gas if you've got a leak. Word of warning, aircon parts can be expensive. Hope you get it sorted.
    West
    Quote Originally Posted by yessof View Post
    How much was the test & regass?
    Jan 2008
    west yorkshire
    Hi, to test the system for leaks is £25, if leak found that's what you pay because it's pointless regassing it. If no leak found £50 which covers test,checks and regas. If you ring Andy he will explain what he does. I don't know him, found him on interweb, but he knows what he is doing and seems to be a genuine guy.
    West
    Sounds good mate, is he mobile or did you visit him... not that am bothered as i'm Bfd based.
    Jan 2008
    west yorkshire
    he's mobile but i went to him
    HULL
    Default AIR CON HELP -Where are the recharge valve
    Hi , I have a 2008 1.9cdti 150 Sri , Just want some help identifying the Aircon recharge valve . Are the aircon pipes the silver ones that run along the front just under the bonnet ?..also how to i know which one is the Recharge.
    Many thanks
  1. H.i.d kit query??
    By Marcosuk in forum Electrical & ICE (including SatNav)
    Last Post: 4th October 2012, 20:07
  2. GSI query?
    By noudder72 in forum Suspension, Wheels & Brakes
    Last Post: 19th January 2011, 10:38
  3. BSR Query
    By Jezzy in forum Petrol Engine related
    Last Post: 26th January 2010, 17:35
  4. Tow bar query
    By Agoogy in forum Vectra C / Signum Car Chat
    Last Post: 11th June 2009, 08:52
  5. GM Oil query
    By SCOTTEX in forum Vectra C / Signum Car Chat
    Last Post: 21st November 2006, 11:43
