Thread: Right another irmscher exhaust question
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Default Right another irmscher exhaust question
    I picked up my shiney new Irmy back box and insert from Dose last night (cheers buddy).
    I eventually decided that yes I did want it and if it needs adapted to fit then i'll just have to do it sooooo.... it needs adapted lol.
    So now here are the figures
    Original exhaust external diameter is 54.69mm
    Irmscher External diameter is 53.20mm
    Irmscher internal diameter is 50.20mm
    So assuming that the original exhaust on the car has a wall thickness of 1.5mm the internal diameter of it would be 51.69
    Of course if some one has a dti/cdti centre pipe sitting and could take the int diameter where it joins the back box it would be much appreciated
    So would this 1.49mm difference in size restrict the engine?
    should I just go and get the end of the pipe (on the back box) flared to 54.69mm
    Or will I have to cut the pipe off of the back box and get the right sized one welded on (massive headache)
    Thanks for reading, hope it makes sense lol
    Regular Member Slick's Avatar
    BEVERLEY
    i wouldnt have thought 1.5mm would have affected the engine if at all personally id just get it flared and fitted as its not as if ur welding it on were u will get a lip inside as ur flaring it so just channels it smoothly
    Personally I would look at cutting the new bits and squeezing them inside the oe stuff.
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    All I did in a similar situation with a 2.2 flowing into a 2.0T system was to cut 2 slots in the larger pipe, slide it over the smaller and clamp it down with some zorst putty, worked perfect with no blow out.
    Wondering lonely as a cloud
    26 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Best bet for that one glad you made you mind up I was interested after seeing paul sessions car but I would have needed the rear bumper too as mine isn't an SRI and it was just to far to travel but it will look good when its on
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Ah see my main worry was about the pipe being smaller and restricting the breathing. So I take it thats not really an issue
    26 Post(s)
    Vehicle : M5
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Its an oil burner john if you want performance by a VXR lol
    It will be fine the Irmscher box has 2 output holes and will more than make up for a minute restriction on the input fill your boots
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Cheers guys, just gotta get the skirt sprayed and then i'll bodge it on
    That's the way
    Regular Member Dose's Avatar
    Falkirk/dunfermline/alloa
    wouldnt think it would affect it in anyway John
  1. Replies: 6
    Last Post: 24th January 2012, 00:11
  2. 3.2 irmscher exhaust should i mod?
    By adfrodsham in forum Petrol Engine related
    Last Post: 7th February 2009, 20:11
  3. Irmscher exhaust question..
    By Kyser143 in forum Styling
    Last Post: 3rd July 2007, 23:23
  4. Irmscher exhaust
    By KC in forum Vectra C / Signum Car Chat
    Last Post: 13th December 2005, 17:46
