Thread: Strange thing happened this morning!!!
    Regular Member stuart813's Avatar
    gosport
    Default Strange thing happened this morning!!!
    Started the car this morning to drive to work and had no power( as if the turbo wasn't working). The spanner light came on so i stopped the car and turned the engine off for about 30 seconds. Then started the car and all seemed well all the way to work and back again. Anyone know what might of caused this and is it likley to happen again or get worse????
    WGAF#5
    hi Stuart - sorry to hear of your dilemma but i cant see from your profile what engine you have?
    if its a petrol - could be a small hole in a pressure hosesolenoid valves or turbo recirculating dump valve issue - if its a diesel - lots of potential problems including the above as well
    might be worth your while reading the fault by the brake pedal test method and then reporting back with the engine type and the fault code stored
    regards
    Dez
    May 2008
    maidstone
    Hi
    I had asimilar problem - but only occurs in the wet!!
    wipers went 'wierd' too!
    what is this 'redaing the fault by the brake pedal test method'?
    I have the 1.9 CDTi (150) engine
    Wittsy
    gosport
    Yeah what's the brake peddle thingy and mine is the 1.9cdti 150 auto.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    It doesnt work in the CDTI's
    Could be the glow plugs? Does the light come on all the time oin startup?
    Gazza4
    gosport
    No goes out once started
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by stuart813 View Post
    im 90% sure its glow plugs but to be absolutely safe get the codes read m8
    Gazza4
    gosport
    i'll see how it is over the next few days. Going to give the EGR valve a good clean and the throtle boddy a clean too
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Watch what you do with the throttle body m8, the part is £380 - i read that on here somewhere.
    Gazza4
    gosport
    Ok Cheers mate
  1. Strange thing happened today?
    By ronnie63 in forum Engine & Drivetrain
    Last Post: 13th September 2012, 16:54
  2. strange thing happened on motorway
    By markmac21 in forum Suspension, Wheels & Brakes
    Last Post: 17th January 2012, 16:45
  3. A strange thing happened yesterday....
    By Weaselbert in forum Vectra C / Signum Car Chat
    Last Post: 8th June 2011, 13:51
  4. fun thing just happened
    By sriturbo20 in forum General Chat
    Last Post: 19th July 2009, 12:28
  5. A strange thing happened...
    By macdad in forum Vectra C / Signum Car Chat
    Last Post: 30th December 2008, 18:40
