Thread: Warning light - little pic of an engine
    Aug 2009
    Gloucester
    Default Warning light - little pic of an engine
    Hi all
    I have the warning light on that looks like a mini engine on the far right bottom of the dash. Anyone any idea what it means? Handbook says somthing to do with exhaust gas flow. My garage couldnt find anything wrong.
    Could it be a sensor or somthing?
    any thoughts
    thanks
    Ian
    Regular Member PORKBALLS29's Avatar
    Epping
    It is the emissions light. Could be either of the 2 o2 sensors or probs with the cat. Have you checked what code it is throwing up?
    Wondering lonely as a cloud
    24 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    I deleted the second post about this as I figured it was finger trouble
    skelmersdale
    Had this prob on both my vec bs,local vaux dealer said couldnt find any probs and wanted to take the bulb out !
    garage i now use said take no notice as vauxhalls are known for this prob mixture just needs to be slightly out,anyhow i took out sensors cleaned and put back remedied it.
    Aug 2009
    Gloucester
    Jeffire
    thanks for that, my garage said they could find no fault but mentioned somthing about the mixture. I wouldnt know where to look for the sensors - are they easy to find ? take out? if so can you describe where to find them and how to get them out ?
    thanks
    Ian
    Regular Member stuartbat's Avatar
    May 2008
    shropshire
    father in laws veccy b had this its to do with emmisions as every 1 has said, All we did to cure it was reset the ecu problem hasnt been back since and its now 6 weeks later
    Newbury
    yes my warning light is on too, previous owner said as already mentioned above that no fault was found. As per Jeffire's initial response I will have a butchers to try and find out where and how to sort the sensors out.
    Vale of Glamorgan
    This light came on my car again yesterday and is still on. It came on a few months ago but a clear of the ECU seemed to get rid of it. Ive cleared Ecu and cleaned the EGR today and still its on. Do you need to clear ECU after cleaning EGR?
    I've got her booked in for a service tomorrow so will see what they say.
    Vale of Glamorgan
    Took the car out last night and to my great joy the light is out again. Hopefully with the EGR and boost sensor cleaned and a full service this morning she should be running like a dream!
  1. Engine warning light
    By shamus5178 in forum Engine & Drivetrain
    Last Post: 15th July 2009, 21:08
  2. engine warning light
    By spooney in forum Petrol Engine related
    Last Post: 20th January 2009, 18:05
  3. Engine Warning Light
    By harveyg77 in forum Engine & Drivetrain
    Last Post: 5th June 2008, 20:35
  4. orange engine warning light
    By markvec in forum Vectra C / Signum Car Chat
    Last Post: 27th August 2007, 22:25
