Thread: worn out rear hub/bearing syptoms?
    Regular Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    Question worn out rear hub/bearing syptoms?
    what are the syptoms of having worn out rear hub/bearings, what can i do to test them to see if they are on their way out?
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    Hi Caveman
    jack up car spin wheel by hand to see if it is noisy,hold wheel at 9 and 3 and rock the wheel to check for any side movement,same again at 12 and 6,there should be no movement or noise,not a bad job to replace just a bit fiddley.change one on my signum it's about one and a half to two hours,
    Regular Member markm's Avatar
    Oct 2006
    Portsmouth
    Rear tyres, check for un-even tyre wear on the inner edge , could be your problem.
    Admin plasma's Avatar
    On the Forum
    312 Post(s)
    Engine : 150
    Mileage : 74000
    isnt that tyre wear a case of camber being out?
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    Oct 2006
    Portsmouth
    most likely but they drown like bearings .
    Jun 2009
    South Coast
    I get no sideways movement but if i rotate the wheel (while jacked up) i get play both forward and backwards, nothing major, not a real big clunk but a little one.. I get this both sides...
    @markm Nothing wrong with my tyres bud that a deffo, they are only a couple of months old and the car had a 4 wheel laser allignment done just 3 weeks ago
    On the Forum
    312 Post(s)
    Engine : 150
    Mileage : 74000
    eek... 12oclock to 6oclock movement is upper control arms
    £70's each from Vx but probably about £30 a pair pattern fart on ebay
    Jun 2009
    South Coast
    rear upper control arms huh.... I have a spare (new) set of those in my garage that i bought a few months back.. I guess I will put them on before I do anything else.. seems like that is my saturday job lined up, its bound to rain now..
    On the Forum
    312 Post(s)
    Engine : 150
    Mileage : 74000
    got mine to do as well... Advisory on MOT last time... Very minimal play on it but not bad for 5yrs useage...
    Jun 2009
    South Coast
    so it will not be an MOT failure then as I have descibed them?.. I have to do my MOT by the 24th of this month and this just started on the way home tonight.. Other than that there is nothing left to fail as i have replaced just about everything else on the running gear..
  1. Wheel bearing worn? Noisy front end!
    By DNS in forum Suspension, Wheels & Brakes
    Last Post: 26th September 2012, 14:37
  2. Worn Thrust Bearing?
    By LeeU in forum Y & Z30DT Specific
    Last Post: 9th August 2012, 09:24
  3. Rear tyres worn REALLY unevenly...What do we think the problem is?
    Last Post: 28th February 2012, 21:30
  4. Rear Tyres worn
    By tangoman in forum Handling & Braking
    Last Post: 15th June 2011, 12:24
  5. rear suspension worn
    By Beavis in forum Vectra C / Signum Car Chat
    Last Post: 22nd December 2005, 16:59
