Thread: 1.8 VVT Engine Issues!!!
    Skelmersdale
    Default 1.8 VVT Engine Issues!!!
    Hi guys. I know this issue has been raised before, (engine rattle on start-up with oil light staying on for approx 5 seconds) and apparently the camshaft pully's need replacing etc.
    I was just wondering if anyone knew were I could purchase a new set of cam pully's, rather than going to the stealers?
    I also have a further problem when first staring the car. When first driving it the car seems to judder on acceleration??
    Any help much appreciated.
    Thanks.
    Skelmersdale
    Bump.
    Skelmersdale
    Bump
    Full Member Big Sig's Avatar
    Come on, someone must know something
    Skelmersdale
    took the words out of my mouth mate haha.
    Have you cheked the plugs are ok?
    Skelmersdale
    Yer they are fine. I have booked it in at the stealers for Friday for a diagnosis. I believe if it is a problem with the camshaft pully's vx charge near enough a grand
    Skelmersdale
    Hi guys. Update from last time. I took the car into my local vx.
    The mechanic advised that in the past he has only changed the camshaft pully's if there is a continuous rattling noise rather than a first start 'rattle'. He advised that I change the oil and filter and try that??? Should I do this or just replace the pully's an all that?
    Which oil would you recommend using? Vx advised 05 30 fully synthetic.
    Jul 2009
    The Rift, Cardiff
    Oil seems the right grade.
    Changing the oil and filter is a lot cheaper and will do no harm, but I cant see it fixing the judder.
    It seems more likely to be clutch / flywheel related?
    I have a 1.8 that judders, sometimes on start up and when its bein used alot. I've recently done a service, filters, oil and plugs, and sadly it made no difference to the judder.
    Skelmersdale
    Hi guys,
    Just a quick update. Changed the oil and filter. Oil used was 0w 30. Has made no difference. Same symptoms, i.e. oil light staying on for 5 seconds on start-up.
    Any further suggestions?
    I am going to take it back to Vx to see what they say.
  1. V6 CDTI engine issues
    By bigdave1701 in forum Vectra C / Signum Car Chat
    Last Post: 21st January 2012, 10:18
  2. I need to clean my engine/bay without electrical issues.How?.
    By felixx in forum Detailing and Car Care Discussion
    Last Post: 19th July 2010, 08:40
  3. Engine Issues? 1.9 CDTi
    By Ean in forum Engine & Drivetrain
    Last Post: 14th April 2009, 19:25
  4. Cruise control and engine temp issues
    By zerocool in forum Engine & Drivetrain
    Last Post: 3rd February 2009, 02:01
  5. engine issues
    By chinky in forum Vectra C / Signum Car Chat
    Last Post: 3rd August 2007, 22:09
