Thread: cdti fuel leak
    Regular Member duncmill's Avatar
    Apr 2009
    manchester
    Default cdti fuel leak
    Has anyone had diesel leaking out of this pipe? is there a quick fix or shall I go to the stealers and give them the £65.00 for a new one.
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Id get a replacement pipe. Wouldnt want to muck about with fuel at that high preasure on a hot engine!
    Apr 2009
    manchester
    Thanks for your advice off to the stealers it is then.
    Carnoustie
    This pipe on mine has ruptured! got the new pipe, how do you remove either end without damage? or do you need to replace other parts connectors?
    thanks Ronnie
    Reading
    I got some really thick fuel hose from a local factors, and used jubillee clips on either end, has been on for 6 months and 10k miles, and not had an ounce of bother, the reason for this was the nearest 2 dealers told me the pipe was on back order with no estimated supply date.
    The worst part of the job was cutting the old pipe off, having to be very careful with the hacksaw so as not to damage the ends
    Carnoustie
    Quote Originally Posted by 137mph View Post
    Cheers for that, when mine broke down the AA guy cut the rubber part out and put a bit of fuel hose on with jubilee clips, held out for a few weeks but has started leaking now, the new pipe was £67, just want to be sure I know what to do before I takle it?
    Ronnie
  1. Fuel leak cdti 150
    By stevoxsi in forum Engine & Drivetrain
    Last Post: 13th February 2013, 11:58
  2. 1.9 cdti fuel leak
    By gnomes in forum Engine & Drivetrain
    Last Post: 28th May 2012, 15:49
  3. 1.9 CDTI Fuel Leak Off Pipes.
    By felixx in forum Engine & Drivetrain
    Last Post: 6th February 2011, 18:28
  4. fuel leak
    By mani2002uk in forum Engine & Drivetrain
    Last Post: 5th October 2010, 16:19
  5. Fuel Leak V6 CDTI.
    By sb1uk in forum Engine & Drivetrain
    Last Post: 14th June 2010, 20:33
vectra c fuel leak site:www.vectra-c.com
