Thread: suspension noises
    Regular Member john-d's Avatar
    Nov 2009
    washington
    Default suspension noises
    i have supersport coilies on my gsi and theyre really starting to **** me off.
    1st problem, every time i turn at slow speed i get 2 clearly audible clunks/twangs (one each side)
    2nd problem at low speed driving my car sqeeks a rediculous amount. sort of like a old bed in a porn film
    any ideas?
    Oct 2009
    bolton
    have them on mine mate with no probs they do take a bit of setting up though cambers etc get them checked by a pro, mine were set up at vauxhall by my mate
    Nov 2009
    washington
    no sqeeky noises on yours?
    Regular Member kentish_bloke's Avatar
    Sittingbourne, Kent
    Vehicle : Insignia
    Engine : 1.8 VVT
    Mileage : 42800
    have you got the rubber sleeves on the bottom coil of the spring, where it sits in the bottom spring seat on the strut?
    also, a mechanic at work suggested putting some spray white grease on the bottom spring seat while the front wheel is jacked up with no weight on the suspension. apparently the yank motors they work on have a similar problem when new springs have been fitted.
    i have similar noises since fitting my Koni springs & have the rubber sleeves & have sprayed them with white grease, so im now suspecting the drop links and/or the ARB bushes.
    Regular Member simon1's Avatar
    Oct 2007
    Leicester
    Vehicle : Vectra elite
    Engine : 1800
    Mileage : 80000
    twangining noise spray grease will cure it and as for the squeek that will be the arb bushes
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    As your running on coilovers I don't think spring seating is the problem here. Were the strut top bearings replaced when you fitted the coilies? Thats where i'd start
    Oct 2009
    bolton
    Quote Originally Posted by john-d View Post
    no mate but but has said by others you do need to soak everything in spray, you have to remember when you fit a kit like this it will highlight any weak bushes etc when mine was first fitted it was awfull we had to obtain be-spoke settings from a company down south who specialise in set ups, the car now is fantastic to drive and sticks to road like glue, stick with it and you will get it right
    Nov 2009
    washington
    yea was about to say there isnt a bottom spring seat with coilies, nope i didnt change the bearings. so bearings, and bushes and lube is the first step?
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Sure is mate
    Nov 2009
    washington
    well i have ordered the bushes and droplinks as i can do those meself, if that cures the sqeeking but not the clunking i will have a friend help me do the bearing. fingers crossed it may do both
  1. Suspension noises!! Newbie needs some help!!
    By Adgti in forum Suspension, Wheels & Brakes
    Last Post: 23rd October 2012, 23:46
  2. Quick help needed - Suspension noises after fitting FKs!
    By Leemarksmith in forum Suspension, Wheels & Brakes
    Last Post: 27th June 2012, 18:08
  3. 3.2 gsi noises
    By noudder72 in forum Engine & Drivetrain
    Last Post: 2nd February 2011, 19:05
  4. Odd noises..?
    By bigdave1701 in forum Vectra C / Signum Car Chat
    Last Post: 26th May 2010, 22:36
  5. Suspension & Steering Noises
    By phil79 in forum Suspension, Wheels & Brakes
    Last Post: 11th February 2009, 00:29
